Topic: More multithreading (Read 23657 times) previous topic - next topic
More multithreading
Hi all,
After @cid42 experimented with multithreading in FLAC, WavPack introduced multithreading and I found out TAK can already multithread over a single file it seemed time to get this working in FLAC too.
I have experimented with openMP a few months ago, but that didn't really work. I've now implemented multithreading with pthreads, which means it works on Windows, Mac and Linux, but only with a compiler that has a pthreads implementation, like mingw has winpthreads. See https://github.com/xiph/flac/pull/634
Anyway, there are a few bugs in there still, but these will probably only crop up when using libFLAC directly, not through the command line tool. Still, please be cautious when using the attached binary. Probably best to only use it for testing. Consider it experimental at this stage.
I've also added two graphs, one with wall time and one with CPU time. The wall time one shows you how fast the encoding process goes (which is of course the most interesting bit of data). The graph has 5 lines, one with FLAC 1.4.3, one with the new code but multithreading not enabled (with the option -j1, which is, use 1 thread), one with -j2 (which is use 2 threads), one with -j3 and one with -j4.
My test PC has a cpu with 2 cores and hyperthreading, so 4 threads in theory. As you can see, 4 threads doesn't really add much over 3 threads in my case. The reason using 2 threads does improve much for fast presets and little (or even get slower) for slow presets is because 1 thread does the housekeeping, and all other threads do number crunching. For fast presets this is reasonably balanced (as much housekeeping to do as number crunching) but for the higher presets the housekeeping thread is mostly idling.
The CPU time graph shows 'efficiency' of some sort: it shows total CPU usage over all cores expressed as a percentage. This more or less shows how much overhead multithreading gives.
I hope there are a few people here that would like to give this a go. Results from systems with more cores are highly appreciated :)
P.S.: compression presets -1 and -3 (edit: that is -1 and -4 of course) use "loose mid-side" which doesn't work well with multithreading. For these presets, the number of threads is limited to 2.
Re: More multithreading
Interesting wall time figures; -5 faster than -4, is that because of the -m vs the -M?
(Offloading a subframe appears a sensible idea to someone who doesn't know squat about compilers ...)
Yes, sorry. I said -1 and -3 but that is -1 and -4 of course
I don't know what you mean?
Dang, it wasn't the dual mono ones ... I did the wrong mental repair.
Because a "naive" way to allocate tasks between threads would be to let one do Left, one do Right, one do Mid and one do Side - or if you got fewer 2 here and 2 there?
My first try was indeed splitting over subframes. The main advantage of that is, that it is completely invisible to the API user. The main disadvantage is the overhead: FLAC is simply too fast. As can be seen from the graphs, the current approach (multithreading over frames) shows a large impact of blocksize. When multithreading over subframes, the amount of number crunching per 'thread-task' is divided by four (assuming stereo input with full stereo decorrelation, which means 4 subframes are tried), which means the overhead increased by more than a factor 4.
It seems there is a certain minimum amount of work that needs to go in a thread-task, otherwise the overhead completely swamps any possible gain. So, if you set a small blocksize, for example 32, multithreading shows massive negative gains.
@ktf
Can I get a Linux binary (or source) to try out?
Sure. Source it at https://github.com/xiph/flac/pull/634 (edit: https://github.com/ktmf01/flac/tree/pthread2 more specifically) Binary is attached, but static binaries on Linux are always less portable then on Windows, so I hope it works.
Binary did work for me, but built a copy from source as well.
Just a quick test with my usual NIN The Fragile album (16/44.1 - 1h 43m) on my Ryzen 5850U
./flac -j1 -8p in.wav - 44.137s
./flac -j2 -8p in.wav - 43.312s
./flac -j3 -8p in.wav - 23.812s
./flac -j4 -8p in.wav - 17.291s
./flac -j5 -8p in.wav - 13.835s
./flac -j6 -8p in.wav - 11.868s
./flac -j7 -8p in.wav - 10.579s
./flac -j8 -8p in.wav - 9.676s
./flac -j9 -8p in.wav - 10.357s
./flac -j10 -8p in.wav - 11.655s
./flac -j11 -8p in.wav - 10.751s
./flac -j12 -8p in.wav - 10.061s
./flac -j13 -8p in.wav - 9.499s
./flac -j14 -8p in.wav - 9.007s
./flac -j15 -8p in.wav - 8.620s
./flac -j16 -8p in.wav - 8.227s
15:42 of CDDA on i7-4790K:
-j1 -8ep - 101s
-j2 -8ep - 99s
-j4 -8ep - 34s
-j8 -8ep - 25s
This thing really works! CDDA -8p -V, 5900x, 12 cores, 24 threads, no accurate science - only watching the numbers :)
j1 103x
j2 106x
j3 203x
j4 298x
j5 381x
j6 460x
j7 543x
j8 620x
j9 685x
j10 705x
j11 725x
j12 740x
j13 750x
j14 752x
j15 750x
I'm seeing that 2 threads doesn't seem like much improvement in encoding speed over only 1 thread.  3 to (insert FPU core count here) is the best improvement.
Compiles fine here also. Own AVX2, GCC 13.1.0 version is 880x for my above using j13.
Thank you all for confirming this works reasonably well on systems with a higher CPU core count.
Care to test that with -0? For -8p it makes complete sense with the following:
maybe just multithread the queue?
What queue?
@ktf: Excellent job!
Tested my set of CDDA-WAVs with "-7 -j[1..12]" on my CPU Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz (6 cores, 12 threads).
My first runs ended up inconsistent (the CPU went hot, the fan ran wild and clock speed was throttled). So I decided to add a 10 second delay between the runs to start each of them with a 45°C-ish CPU (room temp atm is 28°C and rising...).
-j1:	Average time =  22.941 seconds (3 rounds), Encoding speed = 471.29x
-j2: Average time =  20.543 seconds (3 rounds), Encoding speed = 526.32x
-j3: Average time =  10.931 seconds (3 rounds), Encoding speed = 989.08x
-j4: Average time =   8.504 seconds (3 rounds), Encoding speed = 1271.40x
-j5: Average time =   7.401 seconds (3 rounds), Encoding speed = 1460.88x
-j6: Average time =   6.924 seconds (3 rounds), Encoding speed = 1561.60x
-j7: Average time =   6.315 seconds (3 rounds), Encoding speed = 1712.02x
-j8: Average time =   6.540 seconds (3 rounds), Encoding speed = 1653.21x
-j9: Average time =   7.226 seconds (3 rounds), Encoding speed = 1496.26x
-j10: Average time =   7.258 seconds (3 rounds), Encoding speed = 1489.73x
-j11: Average time =   6.862 seconds (3 rounds), Encoding speed = 1575.56x
-j12: Average time =   6.544 seconds (3 rounds), Encoding speed = 1652.20x
No advantage going beyond -j7 in my case (which is 1 housekeeping and 6 number crunching treads, if I understood ktf correctly). Which makes kinda sense if you have 6 physical cores...
Quote from: ktf
Could you elaborate? Do you know why that's the case?
Nice work indeed!
Chris
Hi all,
I've done some more tweaking, hopefully decreasing the time various threads are waiting. Would be great if some people with a CPU with a high core count could benchmark this one vs the previous one.
Quote from: ktf
Loose mid side does the full calculation once every few frames (once every 0.4 s or something) and then uses the result for the next few frames. That a dependency between frames and thus threads. Maybe I'll fix that by implementing a different 'loose mid-side algorithm', perhaps the algorithm that ffmpeg uses.
Here are my results for the v2 binary.
I ran the v1 binary again, since the ambient temp now is 18 °C (21:20 local time) and the CPU fan didn't run so fast.
ktf_v1 (MD5: 7b2e91271a02ad9ed00666e8a69710fb):
-j1:    Average time =  23.591 seconds (3 rounds), Encoding speed = 458.32x
-j2:    Average time =  20.620 seconds (3 rounds), Encoding speed = 524.35x
-j3:    Average time =  10.757 seconds (3 rounds), Encoding speed = 1005.08x
-j4:    Average time =   7.783 seconds (3 rounds), Encoding speed = 1389.18x
-j5:    Average time =   7.038 seconds (3 rounds), Encoding speed = 1536.23x
-j6:    Average time =   6.827 seconds (3 rounds), Encoding speed = 1583.63x
-j7:    Average time =   6.372 seconds (3 rounds), Encoding speed = 1696.89x
-j8:    Average time =   6.763 seconds (3 rounds), Encoding speed = 1598.70x
-j9:    Average time =   7.168 seconds (3 rounds), Encoding speed = 1508.30x
-j10:   Average time =   7.333 seconds (3 rounds), Encoding speed = 1474.36x
-j11:   Average time =   6.644 seconds (3 rounds), Encoding speed = 1627.25x
-j12:   Average time =   6.461 seconds (3 rounds), Encoding speed = 1673.51x
ktf_v2 (MD5: 08125e8c74864eb66cf810da273c7c73):
-j1:    Average time =  22.855 seconds (3 rounds), Encoding speed = 473.06x
-j2:    Average time =  20.627 seconds (3 rounds), Encoding speed = 524.18x
-j3:    Average time =  10.813 seconds (3 rounds), Encoding speed = 999.91x
-j4:    Average time =   8.088 seconds (3 rounds), Encoding speed = 1336.85x
-j5:    Average time =   7.196 seconds (3 rounds), Encoding speed = 1502.43x
-j6:    Average time =   7.021 seconds (3 rounds), Encoding speed = 1539.88x
-j7:    Average time =   6.643 seconds (3 rounds), Encoding speed = 1627.58x
-j8:    Average time =   6.673 seconds (3 rounds), Encoding speed = 1620.18x
-j9:    Average time =   7.135 seconds (3 rounds), Encoding speed = 1515.42x
-j10:   Average time =   7.220 seconds (3 rounds), Encoding speed = 1497.44x
-j11:   Average time =   7.102 seconds (3 rounds), Encoding speed = 1522.46x
-j12:   Average time =   6.323 seconds (3 rounds), Encoding speed = 1709.95x
I would not dare to draw a conclusion here, I can't see any significant differences. But maybe your mods don't show at -7.
But my performance peek at -j7 is gone...
flac git-3e2d9a43 20230712
Same test as yesterday.
./flac -j1 -8p in.wav - 44.360s
./flac -j2 -8p in.wav - 41.762s
./flac -j3 -8p in.wav - 23.301s
./flac -j4 -8p in.wav - 16.781s
./flac -j5 -8p in.wav - 13.602s
./flac -j6 -8p in.wav - 11.526s
./flac -j7 -8p in.wav - 10.147s
./flac -j8 -8p in.wav - 9.192s
./flac -j9 -8p in.wav - 10.577s
./flac -j10 -8p in.wav - 11.440s
./flac -j11 -8p in.wav - 10.671s
./flac -j12 -8p in.wav - 10.012s
./flac -j13 -8p in.wav - 9.375s
./flac -j14 -8p in.wav - 8.889s
./flac -j15 -8p in.wav - 8.480s
./flac -j16 -8p in.wav - 8.139s
There are only 6 bytes of difference in header between two binaries?
Speed seems the same.
Might test tomorrow on ancient NUMA system with 2 CPUs x 4 cores x 2 threads = 16 threads
Indeed both versions claim git-ea9a6c00 in Windows details. I only benched -j13 for both and the speed is the same.
The one i can compile atm sourced as pthread2.zip claims to be 1.43.
btw. Clang does clearly worse here for me.
AMD Ryzen 9 5950X (16 Cores 32 Threads)
Codec      :     PCM (WAV)
Duration   :     1:41:59.985
Sample rate:     41000 Hz
Channels   :     2
Bits per sample: 16
flac-multithreading-win
timer64.exe v1 -j1 -8p -f in.wav
Global Time  =    60.385
timer64.exe v1 -j2 -8p -f in.wav
Global Time  =    59.729
timer64.exe v1 -j3 -8p -f in.wav
Global Time  =    35.290
timer64.exe v1 -j4 -8p -f in.wav
Global Time  =    29.652
timer64.exe v1 -j5 -8p -f in.wav
Global Time  =    22.567
timer64.exe v1 -j6 -8p -f in.wav
Global Time  =    19.046
timer64.exe v1 -j7 -8p -f in.wav
Global Time  =    19.110
timer64.exe v1 -j8 -8p -f in.wav
Global Time  =    14.793
timer64.exe v1 -j9 -8p -f in.wav
Global Time  =    12.196
timer64.exe v1 -j10 -8p -f in.wav
Global Time  =    10.990
timer64.exe v1 -j11 -8p -f in.wav
Global Time  =     9.952
timer64.exe v1 -j12 -8p -f in.wav
Global Time  =     9.068
timer64.exe v1 -j13 -8p -f in.wav
Global Time  =     8.388
timer64.exe v1 -j14 -8p -f in.wav
Global Time  =     7.899
timer64.exe v1 -j15 -8p -f in.wav
Global Time  =     7.362
timer64.exe v1 -j16 -8p -f in.wav
Global Time  =     7.079
flac-multithreading-v2-win
timer64.exe v2 -j1 -8p -f in.wav
Global Time  =    60.608
timer64.exe v2 -j2 -8p -f in.wav
Global Time  =    55.049
timer64.exe v2 -j3 -8p -f in.wav
Global Time  =    35.487
timer64.exe v2 -j4 -8p -f in.wav
Global Time  =    27.484
timer64.exe v2 -j5 -8p -f in.wav
Global Time  =    22.866
timer64.exe v2 -j6 -8p -f in.wav
Global Time  =    18.163
timer64.exe v2 -j7 -8p -f in.wav
Global Time  =    14.201
timer64.exe v2 -j8 -8p -f in.wav
Global Time  =    13.424
timer64.exe v2 -j9 -8p -f in.wav
Global Time  =    12.231
timer64.exe v2 -j10 -8p -f in.wav
Global Time  =    10.996
timer64.exe v2 -j11 -8p -f in.wav
Global Time  =     9.890
timer64.exe v2 -j12 -8p -f in.wav
Global Time  =     9.027
timer64.exe v2 -j13 -8p -f in.wav
Global Time  =     8.594
timer64.exe v2 -j14 -8p -f in.wav
Global Time  =     7.857
timer64.exe v2 -j15 -8p -f in.wav
Global Time  =     7.405
timer64.exe v2 -j16 -8p -f in.wav
Global Time  =     6.589
