Topic: ListenBrainz-SMP (Read 2891 times) previous topic - next topic
Re: ListenBrainz-SMP
Nope. But it crashes only because it's not finding the mask file, but you say it's there...
The console should output something like
And the file must exist there.
This one works
X
the console message is lost in all enhanced_playcount ones, sorry
The icons are there
X
Doesn't work, it just skips the image you are missing xd
And I need the log, and you to check if the image is there. And if the image is there, but wine can not load it.. then it's a matter of the png not being compatible with your system
Doesn't crash XD
Then wait a bit, is almost finishing the import
It finished
Z:\home\user\_mask.foobar2000_v2\profile\scripts\SMP\xxx-scripts\images\icons\listenbrainz_64.png
Spider Monkey Panel v1.6.1-mod ({2B889C02-D8C6-4B4D-801F-C8A3512F38FF}): initialized in 571 ms
But this path doesn't look correct, the png is in
Z:\home\user\.foobar2000_v2\profile\scripts\SMP\xxx-scripts\images\icons\listenbrainz_64.png
It finished
And there you got the problem... xd the lovely dots on unix paths...
It finished
it take it like the dot of the extension an insert the _mask?
X]
console clean
Spider Monkey Panel v1.6.1-mod ({2B889C02-D8C6-4B4D-801F-C8A3512F38FF}): initialized in 487 ms
Reply #35
I move the foobar folder and wine prefix to /opt/fb2k with user access and work fine now. ;Maybe the dot could mess up other things.
Just in case
Reply #36
Finally fixed.
Just in case
I'm fine with the previous setting though. Now that I know what to look for, will try to look for similar errors on my code.
Reply #37
https://github.com/regorxxx/ListenBrainz-SMP/releases/tag/v1.6.0
1.6.0 - 2023-02-28
Added
    Playlists: playlists created by the user (in addition to recommendations) can now be imported. They are listed by name and can be sorted by name, creation or last modified date.
    Playlists: playlist exporting to user profile. Note this exporting option is different to the one found at Playlist-Manager-SMP in one thing, the MBID is not saved anywhere (contrary to saving it on a playlist file), so there is no playlist tracking at all and exporting the same playlists multiple times will only update the playlist on the server (instead of creating a new one) as long as the playlist names are strictly equal.
    Playlists: playlist importing by MBID. This allows to import any playlist from any user, not just your own. Input allows the MBID or the link (which also contains the MBID).
    Configuration: added COMPOSER to the list of global tags.
    Configuration: added LOCALE LAST.FM to the list of global tags.
    Configuration: added integrity checks to global user settings files, found at '[FOOBAR PROFILE FOLDER]\js_data\presets\global[...].json'. In particular queries are now check to ensure they are valid and will throw a popup at init otherwise. Other settings are check to ensure they contain valid values too.
    Configuration: expanded user configurable file at '[FOOBAR PROFILE FOLDER]\js_data\presets\global\globSettings.json' with a new setting to output to console profiling logs at script init. They work globally. Disabled by default.
    Toolbar: new settings for text (or icon) position: left, right (default), top and bottom. These settings mimic CUI options at the buttons bar.
    Toolbar: new settings for text scale (now independent of button and icon scale).
    Toolbar: new settings for icon scale (now independent of button and text scale).
Changed
    Configuration: changed the remove duplicates bias to prefer tracks with higher play-counts and positive feedback tag (love/hate).
    Helpers: updated helpers.
    Console: improved log file formatting on windows text editors which parse new lines only with CR+LF instead of LF.
    Code cleanup.
Removed
Fixed
    Playlist Recommendations: importing playlists did not retrieve all possible Youtube tracks in some cases.
    Track Recommendations: not retrieving any result due to API changes.
    Toolbar: buttons' size not restored back to normal height after disabling 'Full size buttons' without reloading the panel.
    Helpers: added missing helper.
    UI: wrong parsing of png masks on unix systems (currently, it only affected the ListenBrainz icon when changing the font color).
    Minor fixes.
