Topic: Help finding software - Philips DSD to DST Encoder (Read 1410 times) previous topic - next topic
Hello !
I am currently searching for any software able to compress DSD (.dsf or .dff files) into DST (.dff files).
The only software able to do what I want (from what I read) is the "Philips ProTECH DST Encoder 4.0.3".
I really want help because I can't find anything : I've been digging int the Internet for 3 hours, and almost nothing (except other people asking "how to convert DSD to DST" :'( ).
The last time this software was available to download was in 2013 (already 10 years....).
Even the Wayback Machine cannot help me since they used a third-party online storage website.
https://web.archive.org/web/20110728110145/http://avaxhome.ws/software/software_type/multimedia/Converters/Philips_ProTECH_DST_Encoder_4.0.3.html
https://web.archive.org/web/20141106042140/http://avaxhm.com/software/software_type/multimedia/Converters/Philips_ProTECH_DST_Encoder_4.0.3.html
I am aware of WavPack DSD compression, but it's not as great as DST. Typically, WavPack was able to compress to ~50%, while DST files are only ~41% of the uncompressed size ! See here : http://archimago.blogspot.com/2017/11/musings-on-dsd-compression-and.html
If you want real numbers (or up to date, since the link I gave is 6 years old), I can run a small benchmark.
Why I want this ?
Because I have uncompressed .dff files and want to compress them to save space.
I know a software supporting DST that can decode it and use my USB DAC in native DSD mode.
Thank you very much for help and time.
Re: Help finding software - Philips DSD to DST Encoder
Here's a DST encoder.
I'm told it's very slow, but I don't have any DSD audio to test it.
Found this on the interwebz. VirusTotal says it is OK. Use on your own risk!
gold plated toslink fan
Thank you very much to both of you !!!!!!
For now I only tested the one Octocontrabass sent, and it works with wine under Linux (on the small samples provided in the archive).
From what I already saw, Octocontrabass's software have the source code in the archive, and prebuilt binaries are made (for Windows), while the one sent by Markuza is a cracked Windows version, without source code (this is not a critisism, and I'm really glad you sent it).
I'll see if I can do a Linux build of the first software.
I don't really have time now, but I will come back to write a comparison between these 2 softwares, and also will test if they compress completely losslessly.
Speed is not a big deal, as long as it works ^^
Again thank you very much, and stay tuned ;)
Back again !
So I managed to build a x86_64 Linux executable of the one sent by Octocontrabass, really easy so I'm not going to share it (literally just `make`). Just to help: in the `Makefile` , add `-flto -O3 -march=native -static` to CXXFLAGS, CFLAGS and LINK (in order to optimize the compilated code).
I wasn't able to install Philips DST Encoder on Linux with wine, but works perfectly with Windows 11.
DST encoder from MPEG-4 Audio RM Module (MPEG-4 Audio standard ISO-14496-1, 2 and 3):
single core, source code available, decoder and encoder, in terminal (can be automated), worse compression (~48% of original), slower (~10 times when compiled with optimizations)
Philips ProTECH DST Encoder 4.0.3:
mutlicore, closed source code, only encoder, only Windows, only GUI (no automatisation, encodes files one by one manually), better compression (~43% of original), faster.
I think everything was said ^^
If anyone is aware of any other DST encoder, don't hesitate to share it too!
Thanks again for the 2 people who sent me encoders <3
