Topic: Another Seekbar for JScript Panel (Read 1224 times) previous topic - next topic
I wrote a script for a seekbar in CUI with running green bars and gauges in it. The script was for WSH Panel mod. Script engine was JScript9.
DT_TOP = 0x00000000;
DT_LEFT = 0x00000000;
DT_CENTER = 0x00000001;
DT_RIGHT = 0x00000002;
DT_VCENTER = 0x00000004;
DT_BOTTOM = 0x00000008;
DT_SINGLELINE = 0x00000020;
DT_NOPREFIX = 0x00000800;
var g_font = gdi.Font("arial",18,1);
var g_font_rating = gdi.Font("Arial Unicode MS",25,0);
var g_fileinfo = null;
var g_drag = 0;
var g_drag_seek = 0;
var ww, wh, area;
function RGB(r,g,b){
return (0xff000000|(r<<16)|(g<<8)|(b));
function RGBA(r,g,b,a){
return ((a<<24)|(r<<16)|(g<<8)|(b));
function Separator(x) {
this.left = x;
this.draw = function (gr) {
gr.FillGradRect(this.left-1,0, 1, wh-1, 90, RGB(133,133,133), RGB(0,0,0));
gr.FillGradRect(this.left,0, 1, wh-1, 90, RGB(163,163,163), RGB(163,163,163));
gr.FillGradRect(this.left+1,0, 1, wh-1, 90, RGB(60,59,59), RGB(0,0,0));
function separatorsDraw(gr) {
for (i in Separators) {
Separators[i].draw(gr);
function TimeFmt(t){
var zpad = function(n){
var str = n.toString();
return (str.length<2) ? "0"+str : str;
var h = Math.floor(t/3600); t-=h*3600;
var m = Math.floor(t/60); t-=m*60;
var s = Math.floor(t);
if(h>0) return h.toString()+":"+zpad(m)+":"+zpad(s);
return m.toString()+":"+zpad(s);
// --- APPLICATION START
function on_paint(gr){
var pos = 0;
var length = fb.PlaybackLength;
var txt;
if(length > 0){
if(g_drag){
pos = area * g_drag_seek;
txt = "Seek " + TimeFmt(g_drag_seek * length) + " / " + TimeFmt(length);
else{
pos = area * (fb.PlaybackTime / length);
var g_titlefmt = fb.TitleFormat("[%album artist% - ][%album% ]['['%date%']' - ]%title% >> $div($mul(100,%playback_time_seconds%),%length_seconds%) '%'");
txt = g_titlefmt.Eval();
gr.FillGradRect(4, 0, area, wh/2, 270, RGB(90, 90, 90), RGB(0, 0, 0));
gr.FillGradRect(4, wh/2, area, wh/2, 90, RGB(90, 90, 90), RGB(0, 0, 0));
gr.FillGradRect(0, 0, pos, wh/2, 270, RGB(0, 200, 200), RGB(0, 0, 0));
gr.FillGradRect(0,wh/2, pos, wh/2, 90, RGB(0, 200, 200), RGB(0, 0, 0));
gr.FillGradRect(2, 0, 1, wh-1, 90, RGB(163, 163, 163), RGB(163, 163, 163));
gr.FillGradRect(3, 0, 1, wh-1, 90, RGB(60, 59, 59), RGB(0, 0, 0));
separatorsDraw(gr);
gr.FillGradRect(ww-4, 0, 1, wh-1, 90, RGB(133, 133, 133), RGB(0, 0, 0));
gr.FillGradRect(ww-3, 0, 1, wh-1, 90, RGB(163, 163, 163), RGB(163, 163, 163));
gr.DrawRect(0, 0, ww, wh, 4.0, RGB(0,0,0));
gr.GdiDrawText(txt, g_font, RGB(255, 255, 255), 0, 0, ww, wh, DT_CENTER | DT_VCENTER | DT_SINGLELINE | DT_NOPREFIX);
var tfo_rating_a = fb.Titleformat("$if(%rating%,$repeat($char(9733),%rating%),)");
var tfo_rating_b = fb.Titleformat("$if(%rating%,$repeat($char(9734),$sub(5,%rating%)),)");
var txt_rating_a = tfo_rating_a.Eval();
var txt_rating_b = tfo_rating_b.Eval();
gr.GdiDrawText(txt_rating_a, g_font_rating, RGB(0,255,0), ww-120, 0, 110, wh, DT_LEFT | DT_VCENTER | DT_SINGLELINE);
gr.GdiDrawText(txt_rating_b, g_font_rating, RGB(255,0,0), ww-120, 0, 105, wh, DT_RIGHT | DT_VCENTER | DT_SINGLELINE);
function on_size(){
ww = window.Width;
wh = window.Height;
area = ww - 4;
Separators = {
one: new Separator((ww-4)/10),
two: new Separator((ww-4)/5),
three: new Separator(3*(ww-4)/10),
four: new Separator(2*(ww-4)/5),
five: new Separator(ww/2),
six: new Separator(3*(ww-4)/5),
seven: new Separator(7*(ww-4)/10),
eight: new Separator(4*(ww-4)/5),
nine: new Separator(9*(ww-4)/10)
function on_mouse_lbtn_down(x,y){
g_drag = 1;
function on_mouse_lbtn_up(x,y){
if(g_drag){
g_drag = 0;
g_drag_seek = x / area;
g_drag_seek = (g_drag_seek<0) ? 0 : (g_drag_seek<1) ? g_drag_seek : 1;
fb.PlaybackTime = fb.PlaybackLength * g_drag_seek;
function on_mouse_move(x,y){
if(g_drag){
window.Repaint();
function on_playback_new_track(metadb){
window.Repaint();
function on_playback_stop(){
window.Repaint();
function on_playback_seek(time){
window.Repaint();
function on_playback_time(time){
window.Repaint();
// --- APPLICATION END
Couldn't this script be modified to work on f2k v2 32/64bit with JScript Panel. I just don't know enough about it myself.
Picture see attachment.
Re: Another Seekbar for JScript Panel
After some tests i found that foo_uie_wsh_panel_mod 1.5.10 also works in v2 32bit DUI. I haven't tried it in v2 64 bit yet.
The script (see above) can be copied into the panel and the seekbar will work. (see attachment above)
