Topic: EAC and Cuetools problem (Read 1515 times) previous topic - next topic
Hello, long time reader, new poster here!
I have been using EAC 1.6 with default Cuetools plugin for a long time and erverytime I ripped a CD at the end in the status log file, right after the line "End of status report" it also showed a "---- CUETools DB Plugin V2.1.6" report where it compared the rip against CUETools database but yesterday I tried to update Cuetools to 2.2 version and now CUETools DB Plugin doesn't trigger I have restarted, rebooted the PC... Nothing works and it get worse because after uninstalling and reinstalling EAC default V2.1.6 doesn't work too, there is no way to get CUETools working even in a fresh EAC Installation with default CUETools plugin.
Please help me I'm a bit desperate now!
PS: I have tried to restart EAC and PC, Uninstall EAC and reinstall it with default CUETools, I have also deleted appdata\roaming\EAC folder
Re: EAC and Cuetools problem
Check if you still meet the Microsoft .NET prerequisites http://cue.tools/wiki/CUETools_Download
It may be a recent windows update silently deinstalled older parts.
EAC's settings are stored in the Windows Registry under
Computer\HKEY_CURRENT_USER\SOFTWARE\AWSoftware
which should be cleared with a proper uninstall.
Check that the plugin is enabled (checked) in EAC Options > Audio Plugins
The plugin will not compare a rip with this unchecked.
When unchecked, the setting is stored in the Windows Registry under
Computer\HKEY_CURRENT_USER\SOFTWARE\AWSoftware\EACU\Extraction Options\ExcludedTransferPlugins
Also remember the plugin only adds the results section on full CD rips. It is not added if you rip one or two tracks only.
korth
Thanks Korth! I had to manually remove the registry entry because the uninstaller didn't remove it at all. Problem solved.
