Topic: FLAC-git Releases (Code Base v1.4.x) (Read 34941 times) previous topic - next topic
Re: FLAC-git Releases (Code Base v1.4.x)
Reply #102
Just so thrilled to see new builds again 🥲
Reply #104
Using this version on a somewhat older windows pc using commandline,
flac -8e --no-padding
WARNING, cannot set number of threads: multithreading was not enabled during compilation of this binary
Reply #105
Current git brakes multithreading here completely also.
    Version string : reference libFLAC git-37ca8113 20240306
    Compiler is GCC : ......................... yes
    GCC version : ............................. 13.2.0
    Asm optimizations : ....................... yes
    Ogg/FLAC support : ........................ yes
    Multithreading   : ........................ no
Reply #106
That is strange, I have no such problems. Not on Windows (MinGW64) nor on Linux.
Reply #107
It is the m-ab_s build that compiles without threads. I've tested that, but not an independent build. I'll do that shortly.
This separate build (64 bit, AVX2 optimised) was built with threads enabled:
https://www.rarewares.org/files/lossless/flac-1.4.3-git-37ca8113-20240307.zip
Reply #109
the m-ab_s build
What is that?
Media-AutoBuild_Suite - for building audio and video encoders/decoders and, ultimately, ffmpeg and mpv. It uses configure for the flac build.
Reply #111
Corrected in todays git.
Reply #113
I just built the current git version.  Multi-threading works for me.
Linux x86_64, GCC 12.3.0
flac git-8d4ccdfb 20240308
Reply #114
Not here.
Ops, sorry. No idea what exe files i copied from where for the former test. Recent git indeed still brakes multithreading here.
    Version string : reference libFLAC git-8a685ee7 20240307
Maybe this is related: https://github.com/xiph/flac/commit/0c8afdf35aef9004d013c440bc75b8b77f8f4c26
Reply #115
Well, the build I made at "Reply #107" was from the git of March 7 cloned a few minutes before the time of the post, and threading worked at that point. The m-ab_s build doesn't use cmake and I have no idea whether other build systems default to multithreading, I'm guessing not.
Reply #116
I encountered this problem as well.  The pthread libraries had recently been updated in MSYS2 so I downgraded to the prior version and configure enabled multithreading as expected.  Cmake had no such problem with the latest pthread.
Reply #117
Ah, OK, I guess that explains it. I make use of the MSYS64 install that m-ab_s uses for general GCC compiles but use the cmake build for FLAC.
Reply #118
There seems to be a problem with the latest winpthread in msys2 indeed. One function used by the autotools pthread macro results in an error, making configure think pthread is not available.
Here is the macro documentation that FLAC uses: https://www.gnu.org/software/autoconf-archive/ax_pthread.html
And here is the error that is in config.log
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: C:\msys64\tmp\ccdJznhh.o:conftest.c:(.text+0x8c): undefined reference to `MemoryBarrier'
I'm not sure what to do at this point. Perhaps it is best to leave it for now, as it seems that this is a bug in msys2 that will probably be fixed.
For anyone wanting a quick fix, go to m4/ax_pthread.m4 in the FLAC source directory, and replace lins 331-333
                        pthread_attr_init(&attr);
                        pthread_cleanup_push(routine, 0);
                        pthread_cleanup_pop(0) /* ; */])],
With the following
                        pthread_attr_init(&attr)/* ; */])],
Reply #119
Many thanks! I rolled back winpthreads from r652 to r631 and multithreading is back.
Reply #121
FLAC git-d2b24410 20240309
Built on March 09, 2024, GCC 13.2.0
(Code Base : 1.4.3)
Seems like Msys2 current winpthreads r655 still has the multithreading bug.
I did a working generic git x64 compile for testing. I never started a win32 enviroment, sorry.
Reply #122
Anyone want to try FLAC for ARM64? (a.k.a. aarch64/ARMv8).  Not compatible with Android ARMv8.
FLAC git-49ab34df
GCC 12.3.0
Reply #123
The last update of winpthreads to r731 seems to have fixed the issue.
Reply #124
FLAC git-61f8513c 2024-04-30
Static binaries built with GCC 12.3.0
Linux i386, amd64 and aarch64 (Armv8)
