Topic: foobar2000 v2.0 bugs (Read 135875 times) previous topic - next topic
Re: foobar2000 v2.0 bugs
Reply #451
Is that a bug or drastic misunderstanding on my side?
In ReFacets, I have a column with simply:
if2(%work%,%album%)
But there will be no entries listed which don't have %work%, but have %album%. Those (album names) are still in the "Missing tag" listing, as if I just used "%work%"
Latest beta.
Reply #452
The preferences window does not support ctrl + backspace to delete the current text, although such behavior is present on the rest of panels, windows, popups, etc. On CUI and DUI. Applies to foobar V1 too.
See here:
https://github.com/reupen/columns_ui/issues/572
Reply #453
beta24,In the dark theme mode, 1, the toolbar font is not uniform; 2, when the tabs are crowded, the tab switching is white.
Reply #455
To follow up on the below, it seems that for lossless sources including uncompressed, the verifier component calculates and displays audio MD5s - but apparently only 16 bit and 24 bit, not 8 nor 32 (nor float32/float64).
Another MD5 issue, with WavPack calculating it in the same endianness as the source file. It seems that foobar2000 - like FLAC - calculates it little-endian, and so fails to verify these WavPack files.
Also a wishlist item on the verifier output: yes I can sort by columns (I would have wanted filename with extension) and select, but:
Once there is an option to add to playback queue, surely it should be feasible to send to new playlist?
Reply #456
I have a 192000Hz/24bit 1.7gb flac file.
With foobar vers. 1.5.8 runs fine, with vers. 2.0 beta 24 tells me that the file is corrupt or unsupported format. reference libFLAC 1.2.1 20070917.
I don't know if some flac library needs to be updated.
Reply #457
@ApacheReal : The FLAC library has been updated to one that detects much more errors. There have been a lot of such threads here, the most recent being this: https://hydrogenaud.io/index.php/topic,123715.0.html
What does the verification say? In v2 it is built-in, the old needs this component: https://www.foobar2000.org/components/view/foo_verifier
Are do they report same MD5s?
I wonder if Peter could save himself many quite a lot of questions by including an older FLAC version and whenever a .flac throws an error, run it through the old version to see if the errors are the same, and report an explanation if not.
Reply #458
What I can say that the flac file is not corrupted.
I converted the flac file to wav 24/192 with foobar2000 vers. 1.5.8
Put the wav files in foobar2000 v2.0 beta24 and verified that they were read I proceeded to convert them back to flac 24/192
I don't know more.
I reported the problem, because I think there is something wrong.
Reply #459
Which file did come out corrupted? The one before conversion to WAVE or the one after?
Most of these files that now give errors or warnings, have had ID3 tags written to them by EAC, but this is a high resolution.
Edit: Just because conversion with 1.5.8 does not lead to any objections, it doesn't mean the file is OK - because 1.5.8 uses a FLAC version that does less checks. If you look at https://hydrogenaud.io/index.php/topic,123219.msg1017891.html#msg1017891 you will see a file that was supposed to be 16 bits, but when you decode it, it turns out one channel needs 18 bits and the other needs even more.
Reply #461
XD I love the infinite amount of reports with Playlist Organizer these days, even when people warned this would happen and the component has been reported to be broken since years.
But there it is, at the components list, without a warning. Keep sending reports please, it's really funny. Wonder when we will change the current components model, instead of talking about the philosophy of software.
foobar2000 v2.0 beta24: In Playlist Organizer, right click on a folder, using the popped up context menu, create a new playlist --> Bug. Here is a video of it: https://www.dropbox.com/s/z7gjs08iqo70p4c/Video.mp4?dl=0
Just to be clear in case 3 reports in a year about the component being broken since 2015 is not clear enough. (it's also broken on V1)
IT WILL NOT BE UPDATED; PEOPLE PLEASE STOP USING IT AND REPORTING BUGS.
Reply #462
I'm still having the same problem with beta 25.
metadb, library, playlists.
https://www.mediafire.com/file/bjib5yl93i0fxp9/beta25-playlist-db.7z/file
Components loaded in: 0:00.006179
Configuration read in: 0:00.000461
foobar2000 v2.0 beta 25 x64 [standard]
Playlist #0 loaded in 0:00.118938
User Interface initialized in: 0:00.255285
Loading foo_discogger
foo_discogger: http_client service ready
FFmpeg version: 5.1
Startup time : 0:00.306408
Watching: D:\Music
could not compile SQL:
SELECT info, infoBrowse, size, lastModified, infoBrowseTime, created, attribs, attribsValid FROM metadb WHERE name = ?
database is locked
Library initialized after 0:00.744459
database is locked
database is locked
database is locked
database is locked
database is locked
database is locked
When I open the console window, I often get a "database is locked" error. It occurs when foobar2000 is loaded. And while I can't be specific, it often happens when I try to play a particular file.
There seems to be a delay in the operation of foobar2000 when this DB error occurs.
Components loaded in: 0:00.011037
Configuration read in: 0:00.001171
foobar2000 v2.0 beta 11+log x64 [standard]
Playlist #0 loaded in 0:00.159534
User Interface initialized in: 0:00.386367
FFmpeg version: 5.1
Startup time : 0:00.478256
Watching: D:\Music
Library initialized after 0:02.441319
SELECT info, infoBrowse, size, lastModified, infoBrowseTime, created, attribs, attribsValid, playCount, dateAdded, lastPlayed, firstPlayed, rating FROM metadb WHERE name = ?
database is locked
database is locked
database is locked
database is locked
database is locked
Reply #463
The bugs I found so far appear to be GUI related.
  • Double clicking on a visualization doesn't go to full screen mode.
  • Double clicking with a full screen visualization doesn't exit full screen mode.
  • Exiting full screen mode with a visualization causes it to reshape to the size of the screen and not remember the size and position of where it was last at.
  • Before the open file box pops up (shortcut CTRL + O) any highlighted items in the playlist disappear completely for a brief second before reappearing.
Would Autoplaylist fit here? Also, compatibility with the remote tool?
dj
Reply #464
have a Problem with Beta 25-x64 / Win10 Pro.
When I edit Tags via Properties-Dialog (FLAC FIles) and then save it, Foobar gets unresponsive with 1 Core runs at 100%.
Must kill it with the Taskmanager.
Tags are written.
Reply #465
Yesterday I haven't time to present more Information.
If I edit the Tags on Files which are in my Media Library Path, after saving them, the Properties Dialog don't close and Foobar gets unresponsive.
1 Core gets up to 100%.
Here is a Stacktrace.
ntdll.dll!NtdllDialogWndProc_W+0x100
ntdll.dll!NtClose+0x14
KERNELBASE.dll!CloseHandle+0x45
windows.storage.dll!Ordinal815+0x1319c
windows.storage.dll!SHGetKnownFolderIDList_Internal+0x3887
windows.storage.dll!SHGetKnownFolderIDList_Internal+0x2944
windows.storage.dll!SHGetKnownFolderIDList_Internal+0x282d
windows.storage.dll!SHGetFolderPathEx+0xc3c
windows.storage.dll!SHGetKnownFolderIDList_Internal+0x3043
windows.storage.dll!SHGetKnownFolderIDList_Internal+0x723
windows.storage.dll!SHGetKnownFolderIDList_Internal+0x157
windows.storage.dll!SHGetKnownFolderIDList_Internal+0x6e
windows.storage.dll!SHGetKnownFolderItem+0x2d
windows.storage.dll!IsLibraryCreatedByPolicy+0x2532
shared.dll!uEvalKnownFolder+0x60
foobar2000.exe+0x172b2d
foobar2000.exe+0xa34ae
foobar2000.exe+0xa3711
foobar2000.exe+0x28c8c4
foobar2000.exe+0x161391
foobar2000.exe+0x1e3a79
foobar2000.exe+0x24367c
foobar2000.exe+0x67004
foobar2000.exe+0x242f9b
foobar2000.exe+0x243af7
ucrtbase.dll!configthreadlocale+0x92
KERNEL32.DLL!BaseThreadInitThunk+0x14
ntdll.dll!RtlUserThreadStart+0x21
Reply #466
Tags are written.
Problem fixed for the next update, thanks for reporting.
Reply #467
A minor bug, but it seems like the "Visualisation update interval" setting no longer works when the visualiser is put on fullscreen mode. Unfortunately, I'm unable to tell which beta update may have caused the change.
Reply #469
Cue file (multiple tracks onto single FLAC) hangs for ages before playing. Running over a network from a USB2 drive so it's not the fastest but it worked better on the previous version (although that had its own issues in that it paused between tracks - even when playing from the same FLAC - which was why I tried the beta...)
Status bar just shows "Starting playback...", and nothing on the console other than
Opening track for playback: "\\netpath\\Music\StayTheFunkAtHome5.cue" / index: 1
Playing the FLAC file on its own doesn't have nearly as bad a startup time (2 minutes vs <5s). Is FB2k trying to scan every file in the cue before it starts, and doing it multiple times on the same file?
Edit: same pause if I make the mistake of jumping to another track in the cue (so still within the same flac), so it's not just that it's pre-caching some data.
Edit 2: oh, it does it between tracks too.
Reply #470
Hi. I've a bug with foobar2000 beta 26-x86 on Win11 Pro.
When the UAC window opens asking for administrator rights, the player crashes if the main window is not minimized (if it is minimized, crashes happen every other time).
I will attach the last four dumps.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 5E25256Ah
Access violation, operation: read, address: 00000000h
Call path:
app_mainloop
Code bytes (5E25256Ah):
5E25252Ah:  CC CC CC CC CC CC 55 8B EC 83 E4 F8 56 8B F1 57
5E25253Ah:  8B 86 D0 01 00 00 8B 78 14 8B 46 64 8B 80 50 01
5E25254Ah:  00 00 F6 40 5B 01 74 27 8B 46 0C C6 86 D5 01 00
5E25255Ah:  00 01 57 8B 80 50 01 00 00 80 48 18 02 8B 4E 0C
5E25256Ah:  FF 37 8B 89 50 01 00 00 E8 D9 96 EE FF EB 07 C6
5E25257Ah:  86 D5 01 00 00 00 8B 07 39 B8 DC 11 00 00 74 06
5E25258Ah:  89 B8 DC 11 00 00 8B 8E D0 01 00 00 FF 75 08 8B
5E25259Ah:  49 0C E8 9F A8 10 00 5F 5E 8B E5 5D C2 04 00 CC
Stack (00AFEC2Ch):
00AFEC0Ch:  087E3AE0 10000000 00000000 03E36FB0
00AFEC1Ch:  03C1F970 15A3B820 80000000 00000000
00AFEC2Ch:  00000000 00000032 00AFEF18 00AFEC58
00AFEC3Ch:  00AFEC54 5E245431 00000200 15988900
00AFEC4Ch:  15D49000 01216758 00AFF0D8 5E302BDC
00AFEC5Ch:  00000200 00000000 00000000 000001AB
00AFEC6Ch:  00000090 00000000 00000000 000001AB
00AFEC7Ch:  00000090 01215350 5E301EE0 006C6C64
00AFEC8Ch:  65747379 5C32336D 00000144 159886A0
00AFEC9Ch:  05651710 0551F880 6F706552 03E36FB0
00AFECACh:  15988900 0563C5E8 00AFF250 00006E69
00AFECBCh:  00000000 00000000 34653766 66343865
00AFECCCh:  38353032 6E5C6331 75646C76 00000000
00AFECDCh:  15D49000 00000010 00000000 00000000
00AFECECh:  00000000 00000000 00000000 00000000
00AFECFCh:  00000090 000001AB 00000000 00000090
00AFED0Ch:  00000000 03D2FF00 00000000 056D0A70
00AFED1Ch:  00000000 00000000 00000000 00000000
00AFED2Ch:  00000000 00000000 00000000 000001AB
00AFED3Ch:  00000090 00000000 00000000 000001AB
Registers:
EAX: 0866DB60, EBX: 0563C5E8, ECX: 03C1F420, EDX: 5F608640
ESI: 0563C5E8, EDI: 00000000, EBP: 00AFEC3C, ESP: 00AFEC2C
Crash location:
Module: nvd3dum
Offset: 108256Ah
Loaded modules:
foobar2000                       loaded at 00CB0000h - 01001000h
ntdll                            loaded at 77BF0000h - 77D9F000h
KERNEL32                         loaded at 76900000h - 769F0000h
KERNELBASE                       loaded at 76150000h - 763BA000h
SHLWAPI                          loaded at 76CE0000h - 76D2B000h
msvcrt                           loaded at 76E40000h - 76F04000h
COMCTL32                         loaded at 6F480000h - 6F6A4000h
WINMM                            loaded at 758E0000h - 75911000h
GDI32                            loaded at 772D0000h - 772F2000h
USER32                           loaded at 773E0000h - 77587000h
ucrtbase                         loaded at 76A70000h - 76B82000h
UxTheme                          loaded at 746C0000h - 7473F000h
win32u                           loaded at 77300000h - 7731A000h
combase                          loaded at 777F0000h - 77A6B000h
gdi32full                        loaded at 763C0000h - 7649E000h
RPCRT4                           loaded at 77730000h - 777E9000h
ADVAPI32                         loaded at 75920000h - 7599C000h
msvcp_win                        loaded at 769F0000h - 76A69000h
dbghelp                          loaded at 74FD0000h - 751A2000h
sechost                          loaded at 776A0000h - 77722000h
OLEAUT32                         loaded at 76D30000h - 76DCC000h
SHELL32                          loaded at 75A70000h - 760D2000h
ole32                            loaded at 77120000h - 7726D000h
CRYPT32                          loaded at 77590000h - 77693000h
shared                           loaded at 6EA50000h - 6EA71000h
zlib1                            loaded at 63AA0000h - 63AB7000h
sqlite3                          loaded at 639D0000h - 63A9B000h
MSVCP140                         loaded at 63960000h - 639CD000h
imagehlp                         loaded at 764A0000h - 764BB000h
COMDLG32                         loaded at 76B90000h - 76C40000h
shcore                           loaded at 77320000h - 773E0000h
MSIMG32                          loaded at 6EA40000h - 6EA46000h
OLEACC                           loaded at 6F420000h - 6F474000h
WINHTTP                          loaded at 6F340000h - 6F416000h
gdiplus                          loaded at 71180000h - 712ED000h
VCRUNTIME140                     loaded at 63940000h - 63955000h
Secur32                          loaded at 753C0000h - 753CA000h
dbgcore                          loaded at 74EE0000h - 74F09000h
SSPICLI                          loaded at 75370000h - 75395000h
IMM32                            loaded at 76C40000h - 76C65000h
kernel.appcore                   loaded at 753F0000h - 75403000h
bcryptPrimitives                 loaded at 76C70000h - 76CD2000h
windows.storage                  loaded at 74810000h - 74EDE000h
wintypes                         loaded at 74740000h - 74807000h
MSCTF                            loaded at 77A70000h - 77B4B000h
foo_bpm                          loaded at 638F0000h - 63931000h
foo_discord_rich                 loaded at 63840000h - 638EC000h
foo_musical_spectrum             loaded at 10000000h - 1001C000h
foo_vis_oscilloscope_d2d         loaded at 63810000h - 6383C000h
d2d1                             loaded at 63320000h - 6380B000h
foo_vis_projectM                 loaded at 63190000h - 6331A000h
OPENGL32                         loaded at 67220000h - 67300000h
GLU32                            loaded at 671D0000h - 67212000h
dxcore                           loaded at 704D0000h - 704FD000h
foo_converter                    loaded at 630F0000h - 63185000h
foo_wave_minibar_mod             loaded at 630A0000h - 630E1000h
foo_ui_std                       loaded at 62EF0000h - 6309C000h
dwmapi                           loaded at 67300000h - 67324000h
foo_input_std                    loaded at 62D30000h - 62EE9000h
avcodec-fb2k-59                  loaded at 62B00000h - 62D21000h
avformat-fb2k-59                 loaded at 62AD0000h - 62AFB000h
avutil-fb2k-57                   loaded at 62910000h - 62ACA000h
MSACM32                          loaded at 628F0000h - 62909000h
bcrypt                           loaded at 74020000h - 7403A000h
foo_dsp_std                      loaded at 628B0000h - 628EB000h
foo_dsp_eq                       loaded at 62840000h - 628AD000h
foo_dsp_crossmix                 loaded at 62830000h - 6283F000h
foo_headphone_eq                 loaded at 033D0000h - 0347A000h
foo_openmpt54                    loaded at 62800000h - 6282E000h
libopenmpt                       loaded at 62660000h - 627FD000h
openmpt-zlib                     loaded at 62590000h - 625A8000h
openmpt-vorbis                   loaded at 625B0000h - 6265B000h
openmpt-mpg123                   loaded at 62550000h - 62589000h
openmpt-ogg                      loaded at 62540000h - 6254B000h
foo_gep                          loaded at 62150000h - 6253A000h
foo_midi                         loaded at 61E40000h - 6214D000h
bass                             loaded at 61DF0000h - 61E3D000h
bassmidi                         loaded at 61D60000h - 61DE1000h
foo_freedb2                      loaded at 61D20000h - 61D53000h
foo_room_eq                      loaded at 03630000h - 03863000h
foo_dsp_vocal_exciter            loaded at 61CF0000h - 61D14000h
foo_vis_vumeter                  loaded at 61C40000h - 61CE5000h
foo_openlyrics                   loaded at 61B00000h - 61C40000h
foo_dsp_vst3                     loaded at 61AA0000h - 61AFC000h
WS2_32                           loaded at 760F0000h - 7614F000h
foo_dsp_effect                   loaded at 03920000h - 03989000h
foo_dsp_utility                  loaded at 61A70000h - 61A92000h
foo_input_ffmpeg                 loaded at 61A30000h - 61A63000h
foo_enhanced_spectrum_analyzer   loaded at 039D0000h - 03A13000h
foo_unpack                       loaded at 619B0000h - 61A29000h
foo_fileops                      loaded at 61950000h - 619AD000h
clbcatq                          loaded at 77B50000h - 77BD2000h
atlthunk                         loaded at 61940000h - 6194E000h
WindowsCodecs                    loaded at 6E8E0000h - 6EA40000h
dataexchange                     loaded at 6ECA0000h - 6ECEC000h
twinapi.appcore                  loaded at 6EAD0000h - 6EC9F000h
TextShaping                      loaded at 6EDC0000h - 6EE55000h
MMDevApi                         loaded at 618C0000h - 6193C000h
DEVOBJ                           loaded at 74260000h - 74284000h
CFGMGR32                         loaded at 744B0000h - 744ED000h
d3d9                             loaded at 67330000h - 674A1000h
VERSION                          loaded at 74F20000h - 74F28000h
directxdatabasehelper            loaded at 6F8E0000h - 6F91C000h
nvldumd                          loaded at 5FD60000h - 5FDF6000h
msasn1                           loaded at 742E0000h - 742EE000h
cryptnet                         loaded at 74610000h - 74637000h
drvstore                         loaded at 74500000h - 74609000h
wldp                             loaded at 74210000h - 74252000h
cryptbase                        loaded at 74F10000h - 74F1B000h
WINTRUST                         loaded at 77270000h - 772C8000h
CRYPTSP                          loaded at 74400000h - 74415000h
rsaenh                           loaded at 743D0000h - 74400000h
nvd3dum                          loaded at 5D1D0000h - 5FD58000h
nvspcap                          loaded at 61690000h - 618BA000h
profapi                          loaded at 753D0000h - 753E9000h
ntmarta                          loaded at 74340000h - 74369000h
gpapi                            loaded at 741E0000h - 74201000h
DWrite                           loaded at 64350000h - 64568000h
textinputframework               loaded at 646C0000h - 647A4000h
CoreMessaging                    loaded at 6F920000h - 6F9ED000h
CoreUIComponents                 loaded at 60740000h - 609D0000h
aticfx32                         loaded at 61500000h - 61684000h
POWRPROF                         loaded at 742F0000h - 74336000h
UMPDC                            loaded at 74370000h - 7437E000h
amdihk32                         loaded at 609D0000h - 609F7000h
sud                              loaded at 60710000h - 60735000h
PROPSYS                          loaded at 710B0000h - 71176000h
ADVPACK                          loaded at 606E0000h - 6070F000h
SETUPAPI                         loaded at 764C0000h - 768FD000h
DUI70                            loaded at 60570000h - 606D2000h
PP-UWP-Interop                   loaded at 60560000h - 6056A000h
vccorlib140                      loaded at 60510000h - 60552000h
Windows.Media.Playback.Backgrou  loaded at 60450000h - 6050E000h
MFPlat                           loaded at 602B0000h - 60446000h
RTWorkQ                          loaded at 60280000h - 602AD000h
Windows.Media.MediaControl       loaded at 60200000h - 60275000h
MFMediaEngine                    loaded at 5FE70000h - 601FE000h
XmlLite                          loaded at 5FE40000h - 5FE6B000h
AUDIOSES                         loaded at 5C240000h - 5C3CA000h
Windows.UI                       loaded at 5C130000h - 5C23A000h
Windows.Media.Devices            loaded at 5C0B0000h - 5C124000h
Windows.Media.Playback.ProxyStu  loaded at 5FE30000h - 5FE3D000h
OneCoreUAPCommonProxyStub        loaded at 5BE30000h - 5C0A9000h
explorerframe                    loaded at 5BC50000h - 5BE24000h
dxgi                             loaded at 70750000h - 7081A000h
d3d11                            loaded at 5BA10000h - 5BC47000h
nvwgf2um                         loaded at 58170000h - 5BA03000h
atiuxpag                         loaded at 5FE00000h - 5FE2E000h
atidxx32                         loaded at 56720000h - 58169000h
avrt                             loaded at 56710000h - 56719000h
resourcepolicyclient             loaded at 56700000h - 56710000h
dsdmo                            loaded at 566C0000h - 566F1000h
msdmo                            loaded at 566B0000h - 566B9000h
atiu9pag                         loaded at 614D0000h - 614FA000h
atiumdag                         loaded at 60A00000h - 614C1000h
atiumdva                         loaded at 5C3D0000h - 5D1C5000h
Stack dump analysis:
Address: 5E245431h (nvd3dum+1075431h)
Address: 5E302BDCh (nvd3dum+1132BDCh)
Address: 5E301EE0h (nvd3dum+1131EE0h)
Address: 5C32336Dh (AUDIOSES+E336Dh), symbol: "Ordinal5" (+348EDh)
Address: 7626C9E8h (KERNELBASE+11C9E8h), symbol: "CloseHandle" (+58h)
Address: 673E1470h (d3d9+B1470h), symbol: "DebugSetLevel" (+1EA0h)
Address: 769163F1h (KERNEL32+163F1h), symbol: "GlobalFindAtomW" (+E1h)
Address: 769163B4h (KERNEL32+163B4h), symbol: "GlobalFindAtomW" (+A4h)
Address: 673053B0h (dwmapi+53B0h), symbol: "DwmExtendFrameIntoClientArea" (+C00h)
Address: 773058FCh (win32u+58FCh), symbol: "NtUserHwndQueryRedirectionInfo" (+Ch)
Address: 7745DB6Dh (USER32+7DB6Dh), symbol: "DwmGetDxSharedSurface" (+4Dh)
Address: 67306422h (dwmapi+6422h), symbol: "DwmpDxGetWindowSharedSurface" (+292h)
Address: 673068FFh (dwmapi+68FFh), symbol: "DwmpDxGetWindowSharedSurface" (+76Fh)
Address: 01000000h (foobar2000+350000h)
Address: 6737A666h (d3d9+4A666h)
Address: 673BF8E7h (d3d9+8F8E7h), symbol: "Direct3DCreate9On12Ex" (+C077h)
Address: 673BF922h (d3d9+8F922h), symbol: "Direct3DCreate9On12Ex" (+C0B2h)
Address: 67379B30h (d3d9+49B30h)
Address: 5E1CBA65h (nvd3dum+FFBA65h)
Address: 00D4B838h (foobar2000+9B838h)
Address: 5E2CBDC7h (nvd3dum+10FBDC7h)
Address: 5E2CE242h (nvd3dum+10FE242h)
Address: 5E2D1824h (nvd3dum+1101824h)
Address: 5E1B8CA3h (nvd3dum+FE8CA3h)
Address: 5E2E35F8h (nvd3dum+11135F8h)
Address: 5E2EDAC4h (nvd3dum+111DAC4h)
Address: 5E35CD48h (nvd3dum+118CD48h), symbol: "QueryOglResource" (+53428h)
Address: 5E35CE4Fh (nvd3dum+118CE4Fh), symbol: "QueryOglResource" (+5352Fh)
Address: 67373C74h (d3d9+43C74h)
Address: 67373C79h (d3d9+43C79h)
Address: 673AEA60h (d3d9+7EA60h), symbol: "Direct3DCreate9" (+3E0h)
Address: 673B79FCh (d3d9+879FCh), symbol: "Direct3DCreate9On12Ex" (+418Ch)
Address: 67372815h (d3d9+42815h)
Address: 00E36FB0h (foobar2000+186FB0h)
Address: 67467240h (d3d9+137240h), symbol: "Direct3DShaderValidatorCreate9" (+41DA0h)
Address: 67392970h (d3d9+62970h), symbol: "Direct3DCreate9Ex" (+A250h)
Address: 673A6A96h (d3d9+76A96h), symbol: "Direct3DCreate9Ex" (+1E376h)
Address: 673A6A50h (d3d9+76A50h), symbol: "Direct3DCreate9Ex" (+1E330h)
Address: 5E2F8A0Ah (nvd3dum+1128A0Ah)
Address: 5E2F8990h (nvd3dum+1128990h)
Address: 674537F1h (d3d9+1237F1h), symbol: "Direct3DShaderValidatorCreate9" (+2E351h)
Address: 67390E07h (d3d9+60E07h), symbol: "Direct3DCreate9Ex" (+86E7h)
Address: 67390DC0h (d3d9+60DC0h), symbol: "Direct3DCreate9Ex" (+86A0h)
Address: 6740B70Bh (d3d9+DB70Bh), symbol: "Ordinal23" (+1E56Bh)
Address: 6740B5ABh (d3d9+DB5ABh), symbol: "Ordinal23" (+1E40Bh)
Address: 61C576D2h (foo_vis_vumeter+176D2h), symbol: "foobar2000_get_interface" (+C636h)
Address: 61C578A4h (foo_vis_vumeter+178A4h), symbol: "foobar2000_get_interface" (+C808h)
Address: 61C57D1Eh (foo_vis_vumeter+17D1Eh), symbol: "foobar2000_get_interface" (+CC82h)
Address: 61C4A47Dh (foo_vis_vumeter+A47Dh)
Address: 61C56437h (foo_vis_vumeter+16437h), symbol: "foobar2000_get_interface" (+B39Bh)
Address: 61C48E2Eh (foo_vis_vumeter+8E2Eh)
Address: 774123E3h (USER32+323E3h), symbol: "Ordinal2713" (+6B3h)
Address: 774030E6h (USER32+230E6h), symbol: "CallWindowProcW" (+716h)
Address: 77402D9Ah (USER32+22D9Ah), symbol: "CallWindowProcW" (+3CAh)
Address: 7740D8E9h (USER32+2D8E9h), symbol: "GetWindowThreadProcessId" (+2A9h)
Address: 707CF590h (dxgi+7F590h), symbol: "DXGIGetDebugInterface1" (+E7B0h)
Address: 77C6870Dh (ntdll+7870Dh), symbol: "KiUserCallbackDispatcher" (+4Dh)
Address: 77414EB0h (USER32+34EB0h), symbol: "WindowFromPoint" (+F40h)
Address: 77402B6Ah (USER32+22B6Ah), symbol: "CallWindowProcW" (+19Ah)
Address: 77C87B80h (ntdll+97B80h), symbol: "NtdllDialogWndProc_W" (+160h)
Address: 7740CADFh (USER32+2CADFh), symbol: "GetPropW" (+FFh)
Address: 707CF6E3h (dxgi+7F6E3h), symbol: "DXGIGetDebugInterface1" (+E903h)
Address: 7740EABFh (USER32+2EABFh), symbol: "TranslateMessage" (+15Fh)
Address: 77C68640h (ntdll+78640h), symbol: "KiUserApcDispatcher" (+70h)
Address: 773013ACh (win32u+13ACh), symbol: "NtUserDispatchMessage" (+Ch)
Address: 77401AE4h (USER32+21AE4h), symbol: "DispatchMessageW" (+604h)
Address: 77C6614Ch (ntdll+7614Ch), symbol: "ZwCallbackReturn" (+Ch)
Address: 7740D834h (USER32+2D834h), symbol: "GetWindowThreadProcessId" (+1F4h)
Address: 77403A44h (USER32+23A44h), symbol: "IsDialogMessageW" (+854h)
Address: 62FC3FBDh (foo_ui_std+D3FBDh)
Address: 00D7BCFFh (foobar2000+CBCFFh)
Address: 00F8F094h (foobar2000+2DF094h)
Address: 00EE806Ch (foobar2000+23806Ch)
Address: 00F77E68h (foobar2000+2C7E68h)
Address: 00D7BE19h (foobar2000+CBE19h)
Address: 00D7D25Dh (foobar2000+CD25Dh)
Address: 00F16414h (foobar2000+266414h)
Address: 00D7D0F1h (foobar2000+CD0F1h)
Address: 76AA989Dh (ucrtbase+3989Dh), symbol: "crt_atexit" (+3Dh)
Address: 76B7571Ch (ucrtbase+10571Ch), symbol: "mbcasemap" (+16Ch)
Address: 00F9157Ch (foobar2000+2E157Ch)
Address: 00ED737Bh (foobar2000+22737Bh)
Address: 00EE82D5h (foobar2000+2382D5h)
Address: 00ED6F98h (foobar2000+226F98h)
Address: 00ED701Ch (foobar2000+22701Ch)
Address: 00ED69FEh (foobar2000+2269FEh)
Address: 76917D69h (KERNEL32+17D69h), symbol: "BaseThreadInitThunk" (+19h)
Address: 76917D50h (KERNEL32+17D50h), symbol: "BaseThreadInitThunk" (+0h)
Address: 77C5B74Bh (ntdll+6B74Bh), symbol: "RtlInitializeExceptionChain" (+6Bh)
Address: 77C6E8B0h (ntdll+7E8B0h), symbol: "wcstombs" (+70h)
Address: 77C5B6CFh (ntdll+6B6CFh), symbol: "RtlClearBits" (+BFh)
Address: 77C88674h (ntdll+98674h), symbol: "RtlCaptureContext" (+F4h)
P.S.: nvd3dum.... I assumed that this is due to the included visualizers (and specifically the oscilloscope), but my assumption turned out to be wrong. I do not know what to do.
P.P.S.: My computer has two video adapters, and the player runs on a weaker video adapter. I can't say exactly what version the problems started with, but the first dump was created on January 18th. Then I did not pay attention to it.
Reply #471
I have 2.0 beta 26 x64. But I didn't found any consistency in crashes except open foobar2000, wait 5+ min, do any action with it =< crash. I have sent 5 reports already. Had no problems with previous installed beta 24.
Reply #472
Moreover, the player crashed after I left the game (closed the application). Both applications are rendered on the same monitor, but through different video accelerators. If necessary, I will send a dump (the program offered to send the report, and I did it).
Reply #473
Problem whit plugin ZXTune Player and foobar2000 v2.0
The .dsf file don't start.
Drag and Drop in playlist don't work.
Loop processed file.
Removed the plugin the .dsf files worked again.
.dsf = Direct Stream Digital (DSD) not Sega Dreamcast format (DSF)
