Re: foobar2000 v2.0 bugs
Reply #586 – 2023-04-03 14:36:55
File Integrity Verifier 1.4.2 and integrted version in foobar 2.0 has a bug: When using "Verify album with acurate rip" shows that disc is not acurate if the whole disc or some of the tracks are HDCD and foo_hdcd.dll is installed If i remove foo_hdcd.dll, then "Verify album with acurate rip" shows that disc is acurate. The same problem is when CD is tagged as Pre-emphasis and foo_deemph.dll 0.1.1 is installed, "Verify album with acurate rip" shows that disc is not acurate So i think File Integrity Verifier must ignore all postprocessing decoders, like foo_hdcd.dll, foo_deemph.dll and others @Peter, why there is no option in foobar to temporary disable installed postprocessors, like the checkbox options in 'Playback > Decoding' menu? Bug acknowledged and fixed for the next update, normal Verifier suppresses postprocessing, I forgot to do this for AccurateRip checking. I don't think a global switch for it is feasible, it's something negotiated between decoders and frontends. Though individual postprocessing components could implement their own switches.Version 2, Beta 30 x64 Bug in Converter, showing the output preferences for FLAC/PCM whenever using a lossy encoder. Image attached from Converter dialog, showing "Output 24 bit" but the output is AAC. I checked my preset settings too, they're normal. Acknowledged, thanks for reporting.Here's a bug with the File operations dialog in dark mode. Switching between Rename and Move turns one of the checkbox labels black. Acknowledged, thanks for reporting.
