Re: EAC in Linux (can't create folder via Filename option)
Reply #2 – 2022-08-27 02:07:18
Which distro are you using? I get some sort of "severe issue" popup box every time I open EAC in my Linux Mint (Mate, 20.4) . I can close the message and EAC works fine except for the two KNOWN issues (there may be more that I have yet to discover): Can't create folder via "\" Filename option. I can set the Default EAC folder, and I see it in the Use This Directory option. But EAC never obeys this rule when it comes time to ripping as it opens the Save As windows with the orig default location: /home/file625/.wine/drive_c/Program Files (x86)/Exact Audio Copy/Microsoft.VC80.CRT The open popup box error in detail:Unhandled exception: page fault on read access to 0x00000001 in 32-bit code (0x610b61e0). Register dump: CS:0023 SS:002b DS:002b ES:002b FS:0063 GS:006b EIP:610b61e0 ESP:006dcb50 EBP:7ffd1000 EFLAGS:00010257( R- -- I Z-A-P-C) EAX:00000000 EBX:612ff9fc ECX:00000000 EDX:00000000 ESI:002319e8 EDI:00000001 Stack dump: 0x006dcb50: 7bc4c100 00000057 00000020 612ffa14 0x006dcb60: 00000076 00000076 006dcb98 7bc508db 0x006dcb70: 61301088 00000000 7bc5ac40 7bc411e0 0x006dcb80: 612156aa 613009d8 00000003 612ff9fc 0x006dcb90: 613010fc 00000000 006dcc28 610b66c3 0x006dcba0: 612ff9fc 00000001 00000000 006dcbf0 Backtrace: =>0 0x610b61e0 GetCommandLineA@0+0x2bef0() in cygwin1 (0x7ffd1000) 1 0x610b66c3 GetCommandLineA@0+0x2c3d3() in cygwin1 (0x006dcc28) 2 0x610b6ba8 GetCommandLineA@0+0x2c8b8() in cygwin1 (0x006dccd8) 3 0x6100754e __assert+0x589e() in cygwin1 (0x006dccd8) 4 0x6100609b __assert+0x43eb() in cygwin1 (0x00000000) 5 0x61006151 __assert+0x44a1() in cygwin1 (0x006dff18) 6 0x61007261 __assert+0x55b1() in cygwin1 (0x006dff18) 7 0x0047a303 in cdrdao (+0x7a303) (0x006dff18) 8 0x0040103f in cdrdao (+0x103f) (0x006dff30) 9 0x7b62e990 WriteTapemark+0x100(device=7FFD1000, type=0x7ffd1000, count=0, immediate=0x6dffec) [Z:\usr\src\packages\BUILD\dlls\kernel32\tape.c:317] in kernel32 (0x006dff48) 10 0x7bc5b4e7 RtlWakeConditionVariable+0x57(variable=7B62E980) [Z:\usr\src\packages\BUILD\dlls\ntdll\sync.c:766] in ntdll (0x006dff5c) 11 0x7bc5bba0 RtlCreateUserThread(entry=00401000, arg=7FFD1000) [Z:\usr\src\packages\BUILD\dlls\ntdll\thread.c:261] in ntdll (0x006dffec) 0x610b61e0 cygwin1+0xb61e0: movzbl 0x1(%eax),%ecx Modules: Module Address Debug info Name (22 modules) PE 00400000-004da000 Export cdrdao PE 012a0000-01a7a000 Deferred user32 PE 01a80000-01c6a000 Deferred gdi32 PE 61000000-61500000 Dwarf cygwin1 PE 61500000-61579000 Deferred iphlpapi PE 61740000-6182f000 Deferred advapi32 PE 62fc0000-63204000 Deferred rpcrt4 PE 63480000-6349c000 Deferred version PE 66b00000-66b5c000 Deferred win32u PE 688c0000-68940000 Deferred netapi32 PE 6a280000-6a4eb000 Deferred msvcrt PE 6bc00000-6bca3000 Deferred sechost PE 6bcc0000-6bea4000 Deferred setupapi PE 6ca80000-6cbb8000 Deferred wldap32 PE 6d780000-6d7fe000 Deferred ws2_32 PE 6e4c0000-6e4fe000 Deferred dnsapi PE 6f480000-6f49c000 Deferred nsi PE 70b40000-70e11000 Deferred ucrtbase PE 71200000-7124c000 Deferred imm32 PE 7b000000-7b300000 Deferred kernelbase PE 7b600000-7b920000 Dwarf-4 kernel32 PE 7bc00000-7be99000 Dwarf-4 ntdll Threads: process tid prio (all id:s are in hex) 00000038 services.exe 0000003c 0 00000040 0 0000004c 0 00000050 0 00000074 0 00000098 0 000000b0 0 000000e4 0 000000e8 0 000000ec 0 00000044 winedevice.exe 00000048 0 00000054 0 00000058 0 00000064 0 00000068 0 000000bc 0 0000006c winedevice.exe 00000070 0 00000078 0 0000007c 0 00000080 0 00000084 0 00000088 0 0000008c 0 00000090 plugplay.exe 00000094 0 0000009c 0 000000a0 0 000000a4 0 000000a8 svchost.exe 000000ac 0 000000b4 0 000000b8 0 000000c0 explorer.exe 000000c4 0 000000c8 0 000000cc 0 000000d4 rpcss.exe 000000d8 0 000000f0 0 000000f4 0 000000f8 0 000000fc 0 00000100 0 00000104 0 0000010c EAC.exe 00000110 0 00000114 0 00000118 2 0000011c 2 00000120 0 00000124 0 00000128 0 0000012c 0 00000130 2 00000134 0 00000138 0 0000013c 0 00000140 0 00000144 (D) C:\Program Files (x86)\Exact Audio Copy\CDRDAO\cdrdao.exe 00000148 0 <== 0000014c 2 00000150 0 0000015c 0 System information: Wine build: wine-7.0 Platform: i386 (WOW64) Version: Windows 7 Host system: Linux Host version: 5.4.0-26-generic
Linux Mint 64-bit. Intel Core i7-9700K CPU @ 3.60GHz × 8 . Kernel Linux 5.4.0-136-generic x86_64. Memory: 16GB. Mesa Intel UHD Graphics 630 (CFL GT2). Various external USB DACs. Schiit, Topping, etc
