Re: EAC and DRM
Reply #25 – 2022-08-22 22:09:22
-594 being the difference in the offset used (600) and the drives actual offset (6). I guess my question is: suppose you aren't using EAC and don't know what your drive offset is. The AR results will probably show you at least one result that says "offsetted by 6", because that's your drive's offset; however, the AR results may also show you "offsetted by 14" or some other number, because your drive's offset is 6, and that particular pressing was written with an offset of 8. If you don't know what your drive's offset is, how are you supposed to pick the correct offset for your drive from the AR log if the disc has multiple pressings with different offsets? As far as I can tell, you can't. You have to look up your drive's offset in the AR database in order to know which offset number to pick if your disc has multiple pressings with different offsets. The only way to use the AR log to find your drive's offset is if you rip a disc that has only one pressing (or multiple pressings that all use the same offset).To emulate without the need for ripping, just verify an image in CUETools then modify the offset in CUETools and verify again I used this method to verify my rip. I changed the CUETools offset to 102 and then verified again, and then AR recognised the disc. I then used the encode mode to split the tracks with the 102 offset applied so I'd get the same WAV files as if I had ripped with the correct 102 offset originally. By "recognised the disc", I mean I did not see this:[AccurateRip ID: 0011590f-008dc7c1-9b0dcc0b] found. Track [ CRC | V2 ] Status 01 [4a5640cb|d2115bf7] (000+000/404) No match 02 [d9d496d2|c5b4c939] (000+000/404) No match 03 [f5363be8|dae8b933] (000+000/404) No match When I saw "no match" (or "not found" -- I don't remember which) upon trying to verify the rip with an offset of 0, I interpreted this as "not accurate" and sought a way to fix the incorrect offset. I just ignored all the other AR results saying "offsetted by x", because I don't know what to do with that information. I'd have to rip the disc again to see what the CUETools log said exactly.
