Topic: jitter from foobar with ADI 2 DAC (Read 1487 times) previous topic - next topic
hi all,
i have heard jitter occasionally from playback with ADI 2 DAC.
i use asio in foobar. however, musicbee seems to be fine which also uses asio.
i updated the firmware and driver of the dac recently but no change.
nevertheless, when i switch to DacMagic Plus there is no jitter.
anyone know why?
regards
Re: jitter from foobar with ADI 2 DAC
Do you mean jitter as in glitching or dropouts?
Tried
* to drop Asio and instead use Exclusive mode? (Playback -> Output)
* Exclusive output overrides, hardware buffer or uncheck/check "Use event"? (Advanced -> Playback, you can type "exclu" in the search box)
Doesn't sound like jitter.
Tried
tried other outputs. it seems asio is the culprit, exclusive or not doesn't matter.
but what is the difference between 'primary sound driver' and madiface driver. do they use windows kernel sound?
