Topic: resizing artwork rotates image on large resolution images (Read 2091 times) previous topic - next topic
I have three CDs, each with large folder.jpgs - 2955 x 2842 is the largest. 600dpi, 24bit deep.
(A bit big I know, but they came straight off the website promoting the release, and I want big images for the TV!)
My resize value is set to 1400x1400 and this is working for other folder.jps that are 1500 x 1500 or that rough size.
For the large ones - 2955 x 2842, the folder.jpg is resized to be within the 1400x1400 range, but it is rotated anti-clockwise 90 degrees. It is displayed like this when encoding and is embedded like this in the mp3 file.
This happens on the:
- 2.20 release
- the build release from @c72578 - https://github.com/gchudov/cuetools.net/files/7945941/CUETools_2.2.0_2022-01-26_git_2a86afa.zip
- 2.16
dpr
Re: resizing artwork rotates image on large resolution images
Hi dpr,
So far, I could not reproduce the reported behavior.
Tested with 2955x2842 600dpi jpg files.
Using this setting:
Advanced Settings - Tagging - Resize if resolution > 1400
Could you please share the link to the jpg files at the website promoting the release, for further investigation?
To check, if there are e.g. exif orientation tags involved etc.
If you prefer, you can send the link as a private message.
Wolfgang
@dpr attached you will find a jpeg file (2955x2842, 600dpi, 24bit), which I used for testing.
The reported behavior could not be reproduced. No rotation occurred.
Please test with this image.
Hi dpr,
Using this setting:
Wolfgang
Apologies, using exiftool, there is a rotate tag in at least image. Will check the rest. I never knew about this.
Thanks. I've been trying to fix it using exiftool and not getting it fixed
It's strange that in windows, if I double click on the folder.jpg it is displayed correctly.
The output from exiftool shows an orientation of 'Rotate 90 CW' see attached.
cuetools copies this into the output folder, but if I open that, it's rotated 90 ANTI CLOCKWISE
I'm guessing the reverse rotation is because it's processing the image data without noticing the rotation tag in the EXIF, and not propagating it to the resulting image, either.
Remark: In addition to the already mentioned Open Source ImageMagick, there are of course other programs around, which can rotate JPG files without loss.
E.g. IrfanView (Freeware):
Options - JPG Lossless Rotation... (PlugIn):
Auto-rotate (according to EXIF orientation, if available)
See attached screenshot.
