Topic: How to enable wvc file? (Read 1006 times) previous topic - next topic
Confirmed that wv and wvc files are at the same folder with same name
But the bit rate are still low.
Anything else I need to do?
Re: How to enable wvc file?
Reload file info. The info doesn't change if you add the .wvc file to the directory after adding the file to a playlist. It will decode correctly, however.
thank you for answering
It doesn't work as well.
I tried open it with other players and non of them work.
So maybe the problem is the file itself.
Are you using the latest version? This was broken for a while. It should be working fine in the latest.
