Topic: TTA refuses this wav file; what's up with it? (Read 2932 times) previous topic - next topic
Recently I scolded TTA for apparently not being able to handle mono .wav files - but it seems it objects to ffmpeg-generated .wav files, mono or stereo. I wonder what is up with the file I attached?
Output from tta.exe -e TTAdoesntlikethis.wav tta.tta
TTA1 lossless audio encoder/decoder, version 2.3
Encoding: "TTAdoesntlikethis.wav" to "tta.tta"
c:\bin\tta-2.3-64bit-sse4\tta.exe: can't read from input file
The .wav was created from a CDDA with ffmpeg.  To get this short file, I gave ffmpeg -i infile.flac -to 0.04 TTAdoesntlikethis.wav, but it doesn't matter if I omit the "-to" part and decode the entire thing to .wav.
However if rather generate the .wav by flac -d, tta is happy.
Tags or not seem not to matter, the attachment is done after removing all tags with fb2k.
Re: TTA refuses this wav file; what's up with it?
By the way, ffmpeg has its own TTA encoder (-c:a tta), so you can transcode directly to tta.
Ah. ffmpeg documentation isn't easy to wrap one's head around.
One can also use CUETools for CDDA, but not for 24-bit, where I found another issue:
24-bit wav generated by flac -d, TTA throws the error "incorrect data size info in wav file"
Edit: Doing it in foobar2000 requires something else than "-e %s %d" ... how? (Being GPL, it could be included in the Free Encoder Pack ... but is there any demand?)
Older ttaenc.exe can encode this file, but it prints a message:
"Encode: skiped unsupported 'LIST' chunk"
Output of sndfile-info for this file:
File : TTAdoesntlikethis.wav
Length : 7134
RIFF : 7126
WAVE
fmt  : 16
  Format        : 0x1 => WAVE_FORMAT_PCM
  Channels      : 2
  Sample Rate   : 44100
  Block Align   : 4
  Bit Width     : 16
  Bytes/sec     : 176400
LIST : 26
  INFO
    ISFT : Lavf58.76.100
data : 7056
End
-eb - %d
if you use "tta-2.3-64bit-sse4"
Those do the trick, thanks.
It does not object to .wav files with metadata added by foobar2000 - it just removes the metadata completely.  So here is TTA's ultra-wise choice for metadata handling:
* Can handle it? Delete!
* Cannot handle it? Refuse to do anything!
... dumber than ffmpeg's ideas of naming a filter:
‘bitexact’
Only write platform-, build- and time-independent data. This ensures that file and data checksums are reproducible and match between platforms. Its primary use is for regression testing.
... I appreciate a mode that strips away problematic chunks, but calling it "bitexact" when it removes bits?!?
