Topic: [EAC Drive Options] Plextor Px-981 Saf Plus (Read 400 times) previous topic - next topic
Hi, setting the EAC parameters I see that this burner has an offset value of +6 in reading. With the CD test for the write parameter I get a value of zero. I put -6 in the writer offset. Do you think it is right? Thanks.
Re: [EAC Drive Options] Plextor Px-981 Saf Plus
write samples offset = combined read/write offset correction - read offset correction
0 - 6 = -6
https://hydrogenaud.io/index.php?msg=915590
korth
Thanks for confirming and ... forgive if I asked you a question that you have already answered dozens of times. If patience had a value...
