Topic: Cannot open GBS m3u playlists on Foobar2000 with Game Emu Player (Read 441 times) previous topic - next topic
GBS music files usually come with m3u playlists that specify track title, length of the track and such but for some reason I cannot open these in Foobar2000 and I get the this message:
Unable to open item for playback (Object not found):
"DMG-APSJ-JPN.gbs::GBS,13,Professor Oak - Junichi Masuda - Pokemon Yellow - ©1998-09-12 Game Freak\, Nintendo,0:35,,10"
I double checked the file name but everything should be correct.
Any idea why this doesn't work? I mean I can open the GBS file directly but I do not have correct playlengths and titles for the tracks then. :/
Re: Cannot open GBS m3u playlists on Foobar2000 with Game Emu Player
Those M3U files are not meant to be opened. If you open the GBS file, GEP will read the duration and tags automatically if the set is tagged properly. What GBS set are you trying to play?
Interesting. Well, I tried Pokemon Yellow GBS from Zophars Domain and it comes with each track in a seperate M3U. I actually downloaded another GBS from somewhere else with just one single M3U that has all tracks in one and this one is actually read properly by Foobar/Game Emu Player. So I guess Foobar or Game Emu Player cannot handle when every single tracks is in a seperate M3U?
EDIT: Nvm. The M3U still doesn't work. It seems like the tags and such are backed into the GBS file themselves. And to top it all off are completely wrong... So yeah, still doesnt work. Actually these GBS files might just be incorrectly tagged. Even the M3U playlists make no sense and are incorrect for the GBS file. Maybe I find a working one somewhere but all seem to have incorrect playlists for the Yellow edition.
Use NEZplug instead of GME. Apparently, even though it has flawed sound, it somehow gets these stupid M3U pieces of shit correct.
In my experience, when I've downloaded XXX+M3U sets, sometimes I've had to change all of the subsong references in the M3Us to be one number higher (0 becomes 1, 1 becomes 2 and so on.) That could be the problem you're experiencing. I've also used Notepad++ to concatenate multi M3U sets into a single M3U before now as like you say it seems to work better in foobar2000 that way. Generally I tend to do the bare minimum to get these sets playing with the correct tags/timers for each song, then from that point create External Tags and save myself any further hassle. If there is a VGM set available I'll just delete these and take that instead because life is too short. There is a VGM set for Pokémon Red & Blue already, and I believe the pack author also had intentions to log the Yellow version exclusive songs in a separate set, though not sure if that has been completed just yet.
