Topic: Title Formatting: $if against list of strings (Read 324 times) previous topic - next topic
I have no idea how to use Search for this particular question:
Is it possible to use the $if statement with an array or a text file with strings?
What I want to achieve:
IF 'WORD' is in 'list-of-exclusions.txt' -> do nothing -> ELSE convert to $Caps.
or the more confusing version
IF 'WORD' is one of 'STRING1,STRING2,STRING3,STRING4...' -> do nothing -> ELSE convert to $Caps.
Specific sample:
Tags are:
Artist: BilliE Eilish
Album: Happier Than EVER
Title: NDA
List 'exclude-from-Caps.txt' has 'NDA','BilliE'
$IF 'WORD' is in 'list-of-exclusions.txt' -> do nothing -> ELSE convert to $Caps
would change the tags to:
Album: Happier Than Ever
Title: NDA
How do you achieve that?
Re: Title Formatting: $if against list of strings
I don't think you can read in a text file directly into a function. The most practical solution for this case would be to capitalize all words, and then decapitalize your exclusions with a long $replace() function. You may also need to insert a placeholder character between words and punctiation marks to make sure your function operates on whole words. If you want to capitalize a word down, then use a different word boundary character, which is not inserted after major punctuation which signals a new sentence. $replace(input,|¦|Billie|¦|,|¦|BilliE|¦|,|¦|The|¦|,|¦|the|¦|). Use Masstagger to make your function more readable by breaking out the replace onto a separate line.
I use this workflow for capitalizing titles, but my exclusions are conventional conjuctions and prepositions, not strange "artistic" capitalization.
You could find a word in a string using $ifgreater($strstr($get(input),BilliE),0,$dosomething(),). But that doesn't help with capitalization because you can't process individual words. It will pass or reject the entire string.
If fb2k scripting supported regex matching, this would be trivial to do.  I saw no mention of regex support at all.  Perhaps this would be a useful feature request for future consideration.
