Topic: File Integrity Verifier (Read 1359 times) previous topic - next topic
Can we add some options to the export? At the moment it spews everything out to a text file which is very difficult to handle. Can we have CSV or some kind of spreadsheet?
Or can we have the option to create a playlist with only the broken files?
Essentially its export function is useless
Re: File Integrity Verifier
While you are waiting for improvements:
You can hit the Status to sort by error messages, and similar about Warnings.
You can select manually, say, all "Failed" with Shift and arrows.
You can right-click and ... well you can move them, copy them, even add them to queue ... but not make a playlist.
Unless you use foo_queuecontents, then you can empty queue first, add these to queue, and copy them from queue over to a different playlist.
