Topic: Two last equalizer bands don't change sound  (Read 787 times) previous topic - next topic
Hello!
In last versions of Foobar2000 for Windows two last equalizer bands don't change sound at all. I was tried to run different software's version, did it on different PCs with many Windows edition, but saw the same. What a reason of the problem and how I may to fix it?
Re: Two last equalizer bands don't change sound
I can't hear much up there, but I can clearly see the 14KHz and 20KHz bands respond to input from the Equalizer.  Maybe your track has no content in those ranges?  This on foobar2000 v1.6.6.
Thanks for the quick response.
You right! I recorded generator signal 15 kHz. I played to DAC (NuPrime uDSD) and hearded the tone of sound.
I need an second answer. For Hi Res 96 kHz is sufficient, but the minimum frequency should be 192 kHz. Why doesn't the player oversample to 192 kHz? For CD rips this would be relevant.
In Foobar 1.6.6, the included RetroArch resampler can do 192k (and +) if you insert it in your DSP chain.  Also, the separate plugin foo_dsp_resampler (SoX resampler) will do 192k.  Your choice if you decide that's what you need.
I had a need for sound correction. To do this, you need to use the equalizer for more than 20 bands. What do you advise?
