Topic: Updated EAC with CUEtool plugin 2.1.9. Now EAC can't see CTDB in settings? (Read 413 times) previous topic - next topic
I have EAC 1.6, installed it maybe 2 weeks ago.
All was working ok-ish. but I had some small issues with CTDB so I decided to update it to latest 2.1.9.
I just overwrote the files in EAC install folder.
Now I can't see the CTDB option among metadata providers in EAC metadata settings.
I only see options freedb or Musicbrainz.
I read some issue with a 2.1.8 dll file existed before so I tried to unregister and re-register Newtonsoft.Json.dll but was unsuccessful in either operation.
"Module was read but no start address found, pls check it is a valid dll"
So, I tried installing an older 2.1.8 plugin version. Same result, can't see CTDB in settings.
I tried searching: EAC fails to detect CTDB (also have tried cuetool aswell)
What now?
Re: Updated EAC with CUEtool plugin 2.1.9. Now EAC can't see CTDB in settings?
I have the same problem. I had to revert to version 2.1.6 of the plug-in.
 -Ok, I'll try that for now.-
EDIT:  Well, 2.1.6.   that did not work for me at this point in time.
Now it feels like a EAC reinstall is my only option.
some suggestions (I'll run some tests tomorrow to see if I can duplicate the issue)
Don't forget to restart EAC after modifying the plugin.
Make sure the plugin is enabled: EAC > EAC Options > Audio Plugins
CUETools 2.1.7 moved to Visual Studio 2017 so the Visual C++ Redistributable may be needed on your system https://www.microsoft.com/en-ca/download/details.aspx?id=48145
You might also want to check if Windows added a block to the zip archive
http://cue.tools/wiki/CUETools_Download#Known_Issues_When_Unpacking_the_Archive
korth
Maybe I should also mention I run Win7.
I have the following installed:
Visual C++ redistri. x86/x64  2005, 2008, 2010, 2012, 2013, 2015(x86), "2015-2019"(x64)
.NET Framework 3.5.1(in Windows functions)  4.7.2 and 4.8 (ordinary install)
I was able to duplicate the issue on my Win7 machine by failing to unblock the zip file in Windows. After applying UNBLOCK and copying the files to the EAC folder, the CTDB plugin 2.1.9 showed up on next start. Info on unblocking in previous reply
korth
