Topic: How to change rip directory in CueRipper (Read 208 times) previous topic - next topic
I would like to avoid having CueRipper CD rips going to any directory containing the username registered on a system since it will be saved on the log file, and perhaps to a flash drive, SD card, or external HDD.
Is there any way to do so? I checked the settings application in AppData but I don't know what template to use to get it to change the directory.
Re: How to change rip directory in CueRipper
You can edit the template in CUERipper by first clicking on the line.
In http://cue.tools/wiki/File:CUERipper215.png you'll notice the path starts in F:\music
All I did was replace %music% with F:\music in the template
CUERipper will save the new template to the settings file on exit.
I should probably add an example on http://cue.tools/wiki/CUETools_Templates
korth
Thanks, this helps a lot.
