Topic: Resampling and encoding in one or two steps (Read 310 times) previous topic - next topic
I use convert to resample a file (using the SoX plug-in under processing) and store it as a FLAC file in one step and in a second step, convert that FLAC file to a lossy file.
If I convert to a lossy file with resampling using the same settings in a single step, I notice the two files are different with bit-compare. I'm curious. Shouldn't these two files be exactly same?
Oh, I meant to post this under General.
Re: Resampling and encoding in one or two steps
no, they should be different.
What's different?
If you convert in 1 step, intermediate results have 32-bit float bit depth.
If you use FLAC then intermediate results have 24-bit (or even 16-bit, depending on your settings) bit depth.
Very small difference, but it's not 0.
I see. Thanks for the info.
