Topic: foobar2000 doesn't read metadata correctly (Read 305 times) previous topic - next topic
Hello,
I recently noticed that foobar doesn't detect my albums, genres and album artists like it used to. I have done the metadata myself using Mp3tag and everything worked fine for months.
From the 2 attached screenshots you can see that the metadata is correct on Mp3tag and detected by foobar however neither album nor genre is showing up in the dedicated foobar windows.
Re: foobar2000 doesn't read metadata correctly
Yes, I had checked it beforehand and it looks fine.
Hi there,
You might need to remove square brackets for Facets columns. See the post here.
Cheers
Oh well I just reloaded my layout and it seems to have fixed it. If it ever happens again I'll give your solution a try.
Thank you anyway.
