Topic: foobar 1.6.6 - Seeking immediately causes playback to stop (Read 338 times) previous topic - next topic
With a particular file, seeking immediately causes playback to stop. Using verify integrity shows status as OK and warnings as <none>. Decode test also doesn't show any errors or warnings. Is there any way to detect files with problems like this? See attached file.
Here is the log from the console
Components loaded in: 0:00.013334
Configuration read in: 0:00.002073
foobar2000 v1.6.6 [portable]
User Interface initialized in: 0:00.206528
FFmpeg version: 4.3.1
Startup time : 0:00.229837
Automatic resampling: using Resampler (dBpoweramp/SSRC), Resampler (RetroArch)
Device: Speakers (TOPPING TP23    )
Mix format: 48000 Hz / 32-bit float / 2 channels (0x3)
Sending stream: 48000 Hz / 32-bit float / 2 channels (0x3)
Opening track for playback: "C:\Users\User\Desktop\New folder\testfile.m4a"
Re: foobar 1.6.6 - Seeking immediately causes playback to stop
This AAC file uses a Dash wrapper which is what causes the seek problem in Foobar.  Dash is used for Internet streaming and can adjust the stream quality dynamically.
A fix is to re-wrap into a "normal" non-dash M4A container using ffmpeg.  From a command window:
ffmpeg.exe -i testfile.m4a -codec copy testfile-2.m4a
Keeps the tags.  Note the need to rename the output file to keep from overwriting the original.
Thanks. Given a folder of files, do you know of a way to detect dash files that are non-seekable?
Sorry, no I don't.  I determined your example was a dash file by using MediaInfo which produced the info pictured below.
You could mass re-wrap all *.m4a in a folder to another existing folder (subfolder "nodash" in example) with this:
FOR %F IN (*.m4a) DO C:\ffmpeg\ffmpeg.exe -i "%F" -codec copy "nodash\%~nF.m4a"
