Topic: Georgia-ReBORN - A Clean foobar2000 Theme (Read 177611 times) previous topic - next topic
Re: Georgia-ReBORN - A Clean foobar2000 Theme
Reply #625
@ApacheReal,
looks crazy, a player in a player like a virtual machine :D
@abc95086,
did you modify your georgia-reborn-configs.jsonc before you did the backup?
If not, it could be problem with CJK chars. Can you post your file path of your "foobar2000\profile\backup"?
I have googled this error and it could also be a storage issue. Maybe permission error because it will try to automatically
create a new directory "backup" in your foobar2000\profile\  or your HDD/SSD could be corrupted. Hard to know for sure...
First make a backup of your "foobar2000\profile\georgia-reborn\configs\georgia-reborn-config.jsonc" file.
Then delete this config file, a new default config file will be recreated on the next foobar startup.
You can remove the "Added" entry in the metadata grid, open your georgia-reborn-config.jsonc file
and go to section: "metadataGrid": [
Remove the this line:
{ "label": "Added", "val": "[$if2(%added_enhanced%,%added%)]", "age": true },
or you can change it to:
{ "label": "Added", "val": "", "age": true },
-TT
Reply #626
@ApacheReal,
@abc95086,
-TT
 I dont modify georgia-reborn-configs.jsonc before remove the "Added", and the path of my backup file is "D:\foobar2000\profile\backup"
Reply #627
What does the Chinese/Japanese signs under ActiveXObject call failed with error (0x80070057) : translate to?
Can you post them here?
Reply #628
參數錯誤(Chinese):Parameter error
Reply #629
Ok, does this always happen for you? Can you try this on another PC?
You can also try to copy D:\foobar2000 to another partition and try to make backup again.
Also what is your foobar version? Version 2.0?
If the crash happens, are any backup files in your "D:\foobar2000\profile\backup" , or is everything empty ( no files ) ?
I have tried on different Windows with different partitions and also on Linux without problems...
Reply #630
I have tried to move foobar to other partition but didnt work, and my foobar version is v1.6.16.
There are two folders in "D:\foobar2000\profile\backup\profile" but doesnt has any files in them.
Reply #631
Ok, I could recreate the crash with foobar v1.6.16.
I will work on fix and will tell you when it's available, thanks for reporting @abc95086!
-TT
Reply #632
-TT
Oh I thought that the 2.0 version is the 64-bit version, so if I just change the foobar version to 2.0, will it solve the problem?
Edit. I have changed my fooabr version to 2.0, it solved the problem.
Reply #634
I never had an issue with this before, but I am trying to update the foobar version from 1.16 to either 2.0 or 2.1 and it completely breaks the interface (georgia no longer looks installed, probably an columnsUI prob?). Both 2.0 and 2.1 64-bit versions do this. It is a portable install.
I am not sure what I'm doing differently than when I updated to 1.16. This also occurs on both Georgia Reborn V2 or if I install the latest release first.
It looks like most of my components are missing in the configuration menu after the Foobar install even though they are still all in the folder directories.
I would just do a clean install but i don't want to reconfigure Foobar to play all of the weird audio formats I collect again.
Reply #635
NVM I remembered that most of the 64-bit plugins required are not available yet so I need to use the 32-bit version. I thought that I was already using 64-bit for whatever reason. Disregard last.
Reply #636
So, I've been searching around for this ever since I updated both foobar and started using the new Georgia-ReBORN release but can't seem to find much of an answer. Searching within my library will intermittently cause foobar to stop responding and crash. Sometimes I'll start searching and it will not respond for a few seconds and then return to normal operation. Other times searching and/or hitting enter on a search will just kill the program.
I'm not sure why this is happening or what I could do to remedy it. I have been searching around for a bit on the forums but could not find any solutions or similar problems to what I'm experiencing. If there's something I've overlooked or misread that has a solution to what I'm describing and one of y'all could point me to I'd greatly appreciate it
Reply #637
Hi @SnappDragon10,
if you don't want to wait for the new upcoming RC-2 release, you can try the latest version from the master.
You can get it from here.
Lots of things have been fixed since RC-1.
-TT
Reply #638
Does anyone else get a random freeze when exiting the program? I get the same thing with my tweaked Darkone. It happened around the time I added ESPLYRICS and Wil-B's BIO, so I'm wondering if it has something to do with either of those.
Reply #639
@Fizbin,
it took me a while to figure this out, but I've encountered this problem and saw that my firewall has blocked the whole foobar directory.
Everything went to normal once I've unblocked it.
-TT
Reply #640
Interesting. I'll look into that. Thanks!
Reply #641
Error: Spider Monkey Panel v1.6.1-mod ({04620F16-1878-47A1-8EFE-0CE0B99566CC}: Georgia-ReBORN v3.0-RC1 by TT)
CreateImage failed:
Failed to create GdiPlus object (0x2): InvalidParameter
File: gr-main-components.js
Line: 764, Column: 39
Stack trace:
  updateDimensions@gr-main-components.js:764:39
  setContainerWidth@gr-main-components.js:748:31
  set_w@main.js:4630:23
  update_items_w_size/<@main.js:3013:9
  update_items_w_size@main.js:3012:18
  update_list_w_size@Control_List.js:476:12
  on_scrollbar_visibility_change@Control_List.js:440:9
  update_scrollbar@Control_List.js:430:9
  on_mouse_move@Control_List.js:183:10
  on_mouse_move@main.js:725:36
  PlaylistPanel/this.on_mouse_move@main.js:312:12
  on_mouse_move@gr-callbacks.js:902:13
Random crash on my end, happening quite a few times. Should I post here?
Reply #643
thank you! I thought  I already downloaded the latest version. I really like your mod , thank you for making these
edit. this new bug just happened
class constructors must be invoked with 'new'
File: Common.js
Line: 821, Column: 9
Stack trace:
  assert@Common.js:821:9
  generate_first_item_to_draw@main.js:3534:3
  generate_items_to_draw@main.js:3425:27
  on_content_to_draw_change@Control_List.js:431:33
  on_content_to_draw_change@main.js:2329:44
  scrollbar_redraw_callback@Control_List.js:441:8
  scrollbar_redraw_callback@main.js:2343:44
  ScrollBar/this.scroll_to@Control_Scrollbar.js:676:9
  scrollFunc@Control_Scrollbar.js:647:9
  ScrollBar/this.smooth_scroll_to@Control_Scrollbar.js:656:3
  scroll_to_row@main.js:3149:20
  scroll_to_focused@main.js:3043:9
  initialize_and_repaint_list@main.js:2199:9
  Playlist/this.debounced_initialize_and_repaint_list<@main.js:920:9
  Debounce/</timerId<@gr-helpers.js:594:30
I just noticed the version didnt change, but I did replace the profile folder from the one you pointed to download from.
Reply #644
[quote author=TT link=msg=1028709 date=1686564044]
I made my mod skin spin disc compatible, I no longer need a virtual machine. :))
Reply #645
@ TT .....looks crazy, a player in a player like a virtual machine
Reply #646
@erusyns,
I thought, I've already fixed this issue... I'll take a look.
The master does not have an newer version number, because it will have one when a new update will be released at the the Github Releases.
The Github Releases have the stable releases, where the master is the latest ongoing development, which can be downloaded anytime
if you click on the green <> Code button and click Download ZIP.
Also all users will be notified when a new update is available on Releases page, when they start Georgia-ReBORN and nothing plays.
A hyperlink will be displayed in the right bottom area of the lower bar.
-TT
Reply #647
@ApacheReal,
yes it looks much better now. You should still improve the CD though.
The inner ring area should be transparent or more visible and you should improve the outer edges,
i.e ( remove 0.5 - 1 cm from the disc art image ).
And maybe make an option to display a sleeve for the CD or some other graphics to make it more pleasing.
-TT
Reply #648
Great to see that you like this spinning vinyl like me.
Reply #649
Hi TT,
I am testing your theme to adapt it to my habits.
I found a lot of interesting things and great ideas.
Many things can be changed directly from the menus which is very convenient.
Over time I made some changes to the Catrox theme, to add useful information to me.
For example I had added PLR calculation (integrated with menu options)
PLR Calculation
My intention are implement it in your's theme but are not easy without changing the code.
I seen that you have added the 3rd line of header customizable.  Could you add another customizable line used for example for the file path or the referenced cue?
Furthermore in options menu I have founded the possibility to "enter your custom playlis track row pattern"
but I haven't found information about sintax.
The attached picture represents what I'd like to achieve without changing the code
(i want add LU disc value in header and LU value in track row)
