Topic: 1.6.7 beta3 new exclusive output mode problem (Read 3480 times) previous topic - next topic
During playback, the sound may be interrupted or the playback speed may slow down.
No problem with foo_wasapi.dll
OS Windows10 Home 64bit Version 21H1
Audio IDT High Definition Audio Codec
Re: 1.6.7 beta3 new exclusive output mode problem
foobar2000 v1.6.7 beta 3 Output: DAC Driver [exclusive]
Continuous playback for about 1 hour (mp3, AAC). Sound cracking is terrible.
I don't use DSP.
NuPrime uDSD, ifi ZEN DAC, iFi nano iDSD, xDuoo X05, Roland UA-M10, FiiO Q1
foobar2000 v1.6.6 WASAPI output support 3.4 (foo_out_wasapi) No problem.
Lenovo G570
Intel(R) Core(TM) i3-2350M CPU @ 2.30GHz 2.30 GHz
16.0 GB
Windows 10 Pro 21H1 19043.985
SHURE SRH1840, SENNHEISER HD660S, Beyerdynamic DT 1990 PRO, HIFIMAN HE5se, Ultrasone Performance 880, AKG K712 PRO, Bowers & Wilkins P7, SONY MDR-1AM2, Bose QuietComfort 35 wireless, SONY WH-1000XM4 (made a Upgrade/Balanced Cable by myself)
The same effect here: after about 20 minutes of Flac playback (CD image with embedded CUE sheet).
It looks a bit to me as if the WASPI settings in the advanced settings are ignored.
Thanks for reporting.
The problem is known and will be addressed for the next update.
WASAPI advanced settings belong to the old WASAPI component and are not utilized. I'll make equivalent settings available for the built-in exclusive output if necessary.
Beta 4 posted, known issues should be addressed.
Exclusive output options are broken on my system in Beta 4, Beta 3 worked correctly. Win 10 20H2, resample & convolver in DSP, DX3Pro DAC (USB 2). This reminds me of the problem I had with the old WASAPI component. It only worked in Push mode with USB2 DAC's unless I installed the DAC's proprietary driver.
foobar2000 v1.6.7 beta 4 Output: DAC Driver [exclusive]
DAC xDuoo X05, FOSTEX HP-A4
The sound is terribly dirty.Worse than beta 3.
Continuous playback is under test.
Unfortunately nothing changed.
Please do, as now one can't choose WASAPI buffer sizes. It'd be much appreciated to have that option back.
foobar2000_v1.6.7_beta_4
Situation became better for me with beta 4, but i still sometimes get glitches on some radio streams if fading is disabled. For example this stream - https://stream.radioparadise.com/rp_192.ogg
Windows 7, realtek
Internal buffer size configuration will be added in beta 5.
Other issues are being investigated, thanks for all the reports.
Sorry...
I reinstalled DAC driver (xDuoo X05 (XMOS) etc).
WASAPI exclusive: All problems have been resolved.
NuPrime uDSD, ifi ZEN DAC, iFi nano iDSD, xDuoo X05, Roland UA-M10, FiiO Q1 and FOSTEX HP-A4.
Beta 5 released.
Default mode is now push instead of event, as with some devices event mode behaves erratically no matter what I try.
Buffer size configuration has been added.
Please test, thanks.
Seems that now exlusive output with fading is fine.
Beta 5 released.
Beta 5 playing music without issues so far. Exclusive push mode works, event does not work. Beta 3 worked in whatever the default mode was. I had the same issue with the WASAPI component and several USB 2 dac's.
(Topping DX3 Pro, fade and DSP in use.
Beta 5 released.
I am using Dragonfly black, Beta5
With smooth seeking enabled and Advanced-Playback-Exclusive mode - Hardware Buffer set to 0 and Use event checked
Above works perfectly, thank you
Dragonfly is USB 1.0, probably why it works in the event mode.
how I can switch to the event mode?
I have USB Class 2 audio working in the exclusive event mode. I set the buffer very small, 12 ms and voila. I think the default was 25 with the WASAPI component. Someone here set it to 0.
Some results of new exclusive mode on fb2k beta 5 and Windows 7. Devices are Realtek and Dr DAC 2 DX (UAC 1 device that uses standard windows driver)
Dr DAC 2 DX, Fading on, Event, buffer 100 ms - OK
Dr DAC 2 DX, Fading off, Event, buffer 100 ms - OK
Dr DAC 2 DX, Fading on, Push, buffer 100 ms - always error "Buffer too large"
Dr DAC 2 DX, Fading off, Push, buffer 100 ms - glitches on local files; error "Buffer too large" on radio stream playback
Realtek, Fading on, Event, buffer 100 ms - playback just doesn't start and no errors are reported; after closing fb2k, process hangs with 25% CPU load and must be killed with task manager.
Realtek, Fading off, Event, buffer 100 ms - almost OK, but "eats" few milliseconds (noticeable by ear) on start of playback
Realtek, Fading on, Push, buffer 100 ms - OK
Realtek, Fading off, Push, buffer 100 ms - on local files it is OK but glitches on radio stream playback
Dr DAC 2 DX, Fading on, Event, buffer 25 ms - OK
Dr DAC 2 DX, Fading off, Event, buffer 25 ms - on local files it is OK but glitches on radio stream playback
Dr DAC 2 DX, Fading on, Push, buffer 200 ms - always glitches in start of playback; after few seconds of playback - error "Buffer too large"
Dr DAC 2 DX, Fading off, Push, buffer 200 ms - OK
Realtek, Fading on, Event, buffer 25 ms - OK
Realtek, Fading off, Event, buffer 25 ms - on local files it is almost OK, but "eats" few milliseconds (but less with 100 ms buffer) on start of playback; glitches on radio stream playback
Realtek, Fading on, Push, buffer 200 ms - OK
Realtek, Fading off, Push, buffer 200 ms - OK
