Topic: World-Map-SMP (Read 15611 times) previous topic - next topic
Re: World-Map-SMP
Reply #50
Need more info, like the configuration you are using.
EDIT: In particular country highlighting option. Shapes option is not for every system...
EDIT2: Anyway, fixed it. There was an infinite painting loop of country shapes XD Sorry.
Shapes should not be used on resource constrained systems, but that was not the problem anyway.
Replace the file. (will update it on github today too)
Re: World-Map-SMP
Reply #51
Back to normal now.
Re: World-Map-SMP
Reply #52
Hi @regor
Are there any options to make the "informative pop-up"  between Prefer nowplaying and Follow selected track (playlist) only show up the first time.
Is a bit annoying close it every time I change the display mode in Bio
Re: World-Map-SMP
Reply #53
Hi @regor
Nope, but makes sense. Will add an option to hide such messages.
Re: World-Map-SMP
Reply #54
Added, look for it in some hours on github. There is a setting to disable it, both popups, the informative one when changing it on BIO and the input popup when doing it on World Map.
(you will probably need to update all my scripts to the latest on github, and since Wine always give so much problems with SMP... better you make backups!)
Re: World-Map-SMP
Reply #55
I update them often. You code a lot  :P . Happily, I have not had new problems (fingers crossed)
Re: World-Map-SMP
Reply #56
Great :) Will have it in mind, to not upload partial updates then!
Re: World-Map-SMP
Reply #59
New release:
https://github.com/regorxxx/World-Map-SMP/releases/tag/v2.5.0
Fixes all instances of weird chars on Wine. Fonts are now configurable globally.
Re: World-Map-SMP
Reply #60
https://github.com/regorxxx/World-Map-SMP/releases/tag/v2.6.0
## [2.6.0] - 2023-03-04
### Added
### Changed
- UI: disabling the panel now shows the world map background (instead of just the filling color).
- Internal code cleanup of menus.
### Removed
### Fixed
- Console: logging of null value not working properly (totally irrelevant except for debug purposes).
Re: World-Map-SMP
Reply #61
https://github.com/regorxxx/World-Map-SMP/releases/tag/v2.8.0
v2.8.0 - Package installation
## [2.8.0] - 2023-05-08
### Added
- UI: new option to set the frequency at which the panel is refreshed after tracks change. Now set to 1000 ms by default. This avoids refreshing the panel when selection changes faster than such value (for ex. while scrolling the library), only updating the panel once afterwards.
- Package: new installation method as package.
### Changed
- Console: multiple improvements when logging to file for FbMetadbHandle, FbMetadbHandleList, Error and unknown instances (totally irrelevant except for debug purposes).
- Console: menu entries are no longer logged to console after clicking.
- Helpers: updated helpers.
### Removed
### Fixed
Script should be installed as package, using the package manager at the Spider Monkey Panel Configuration window. Old method is still supported anyway.
Re: World-Map-SMP
Reply #62
https://github.com/regorxxx/World-Map-SMP/releases/tag/v2.8.2
[2.8.2] - 2023-06-27
Added
Changed
    Tags: improved country names display in some cases (with shorter names).
    Data: updated default database.
Removed
Fixed
    Tags: fix alternate country names in some cases.
    Biography Integration: fix locale tag not updating properly in some cases since 2.8.1.
    UI: script version number.
[2.8.1] - 2023-05-16
Added
Changed
    Biography Integration: optimized processing when Bio Panel notifies tags multiple times, updating just the first time per track.
Removed
Fixed
Re: World-Map-SMP
Reply #64
https://github.com/regorxxx/World-Map-SMP/releases/tag/v2.9.0
[2.9.0] - 2023-07-28
Added
Changed
    Configuration: database now uses album artist by default instead of artist (file translation is done automatically).
    UI: improvements to panel updating when changing selection or updating tags, ensuring panel does not update unnecessarily.
    UI: locale values are cache during the session, to be reused in case tags, Bio or JSON don't have a match.
Removed
Fixed
    Fix for non standard hyphen chars on path names.
Re: World-Map-SMP
Reply #65
v3.0.0 - Statistics mode
https://github.com/regorxxx/World-Map-SMP/releases/tag/v3.0.0
[3.0.0] - 2023-09-13
Added
    Statistics: added statistics mode which can display multiple stats according to the library and database in charts. See Statistics-Framework-SMP.
Changed
Removed
Fixed
    Name replacers not being used at some stages of the code (it probably did not affect anything though).
Re: World-Map-SMP
Reply #66
I have this error:
Error: Spider Monkey Panel v1.6.1-mod (World Map: World Map v3.0.0 by XXX)
getCountryISO is not defined
File: world_map.js
Line: 274, Column: 19
Stack trace:
  @world_map.js:274:19
  @world_map.js:271:24
  fireEvents/</<@callbacks_xxx.js:149:37
  fireEvents/<@callbacks_xxx.js:145:30
Everything was ok until now (this error appears since the last update, it seems). I noticed that it happens when I select a track that has the LOCALE LAST.FM tag. If the file doesn't have the LOCALE LAST.FM tag, the error doesn't appear :)
Re: World-Map-SMP
Reply #67
I have this error:
File: world_map.js
Stack trace:
Your error is technically impossible. Since it says a function doesn't exist, but it exists xd
Is it installed as package or as script file?
Then, in both cases, check where the script/package is, and look for ".\main\world_map\world_map_tables.js". At line 54 there should be:
function getCountryISO(country) {
Re: World-Map-SMP
Reply #68
It's installed as a script file. I'll come back in 10-12 hours when I'll have access to my laptop and I'll let you know how things are working also with the playlist manager
Re: World-Map-SMP
Reply #69
Eventually everything is ok. I installed it again as package and then as script file, 3 or 4 times and then that error has disappeared :)
I don't know if it's still useful but I'll answer your question, anyway. In world_map_tables.js I had this:
Re: World-Map-SMP
Reply #70
Somehow you had an old file version, as I expected. The reinstall fixed it.
Re: World-Map-SMP
Reply #71
https://github.com/regorxxx/World-Map-SMP/releases/tag/v3.1.0
[3.1.0] - 2023-09-25
Added
Changed
    UI: tooltip now shows region and continent for the selected country.
Removed
Fixed
Re: World-Map-SMP
Reply #72
Hi almighty Regor!
May I ask for some kind of management of multiple values (1st) and layers (2nd), please?
I tag %origin-artist% and %origin-composer%, which includes some historical values such as "Constantinople; Byzantine Empire" or "Kingdom of Bohemia", and also %iso3166-composer% with the 3-letter code for the present day country that's in place. I'd be happy with a toggle for artists/composers. Or maybe I'd just try two panels within tabs?
BTW, I can't seem to properly config your script to read my tags. I'm trying different editions in your javascript. Can you point me to the right line, please? (3rd request!)
Regards!
M.
Re: World-Map-SMP
Reply #73
While I'm still trying to properly set up your map, I'm already wishing a timeline script. Maybe an elastic one, which would show greater detail for shorter scales, maybe always showing the five or so composers most represented (by tracks) in each library for the shown period of time - thus you would have a time-navigation thingy along with this space-navigation means
Re: World-Map-SMP
Reply #74
That can be solved with multiple panels, each one pointing to different tags. See below. Adding layers would be unnecessarily complex.
Hi almighty Regor!
Regards!
M.
Historical values are not supported, since they don't have a coordinate associated on the world map. Unless they happen to match the current country name (your ISO code).
X
Open the properties panel and change the first tag to:
$meta(locale last.fm,$sub($meta_num(locale last.fm),1))
%iso3166-composer%
The second one is for writing, which you may leave as is, since you don't want your manually added tags to be overwritten.
As an example, I have copied a bob marley track and added the default locale tag with a ISO code for Spain. You can see that's used on the map fine. If you put there Spain, it would work the same. Both ISO codes and country names are supported.
X
Note current version will display the ISO code on the header (instead of the associated country name like my image), it will be changed on next version. Didn't noticed it since I didn't use ISO codes directly before.
Will also add a direct menu entry to edit the tags for reading/writing.
That sounds interesting, for sure.
