Topic: duration and time progress bar not existing for aac files (Read 299 times) previous topic - next topic
Hi !  When I play aac files, foobar2000 doesn't show any time related information for aac files, though it plays them perfectly
here some file examples
https://cdn.discordapp.com/attachments/605893409353498644/842197403473149962/FF_Quiz_Question_aac.aac
https://cdn.discordapp.com/attachments/605893409353498644/842197447370735666/BGM_ROBJ_Brazier_aac.aac
https://cdn.discordapp.com/attachments/605893409353498644/842197415753809920/BGM_EVT_MarioKart8_Title_aac.aac
If you need more here the complete folder on Google Drive
Thanks in advance for fixing that  : )  !
Re: duration and time progress bar not existing for aac files
You should multiplex your files into MP4 container, for example using MP4Box, or in Matroska, which is much less commonly used. Nobody has defined fields for length and bitrate for ADTS, so the entire file must be parsed to know the duration and seektable for accurate seeking. Other players make an estimate from a small section at the start of the stream.
Following up on j7n's wise suggestion, you can also use ffmpeg to losslessly wrap the AAC's into a M4A container, where they can then be read properly and easily tagged.  If you open a command window in the folder with the AAC's, the following command will do that for all of them;  the originals will be kept.  Change the path for ffmpeg.exe to match yours.
FOR %F IN (*.aac) DO C:\ffmpeg\ffmpeg.exe -i "%F" -codec copy "%~nF.m4a"
If you prefer using Mp4box.exe use this line with the same caveats:
FOR %F IN (*.aac) DO "C:\mp4box\mp4box.exe" -add "%F" "%~nF.m4a" -new
The Mp4box example assumes its needed dependencies are also in the same folder as the exe.
Just in case you want to convert within foobar: I am using the following with foo_run to create a m4a file at the location of the aac file and remove the aac file
cmd /c start "1" "cmd.exe" /k ffmpeg -i "%_path%" -acodec copy -bsf:a aac_adtstoasc -y "$replace(%_path%,%_filename_ext%,)%_filename%.m4a" & ping -n 2 127.0.0.1>nul &cmd /c start "2" "cmd.exe" /k del "%_path%"
Works with foo__run only for one file each, but can probably be extended straight-forward to mass-usage with foo_run_group
Thanks everyone ! So, if I got it right, you're all saying the only way to make duration appear is by converting the sound in another format (and let aac without progress bar forever)
Basically yes - it's just not really 'converting the sound to another format´, more like wrapping your sound into another 'box' that foobar can handle it....
