Topic: Could CUERipper support UTF-8 CUE file encoding? (Read 411 times) previous topic - next topic
CUETools could write CUE file in UTF-8 (BOM) encoding by disable 'Force ANSI filename', but it looks no this option in CUERipper.
Re: Could CUERipper support UTF-8 CUE file encoding?
Sorry, I got called away.before I finished the edit.
\CUERipper\settings.txt
FilenamesANSISafe=0
should turn off 'Force ANSI filename'
This settings file will either be in your user profile (%APPDATA%\CUERipper\settings.txt)
or a sub-folder in the CUETools folder if running as portable (CUETools_2.1.8\CUERipper\settings.txt)
korth
I can't seem to find this in my own CueTools folder. Do you have any sort of guide or screen captures to aid with finding it.
http://cue.tools/wiki/CUETools_Download#Installation
If not running as portable (the user_profiles_enabled file exists in the CUETools folder) the CUERipper settings are in your Windows User Profile
or
C:\Users\YourUserName\AppData\Roaming\CUERipper\settings.txt
If you delete or rename the user_profiles_enabled file, the next time you run CUERipper, a folder and settings file will be created within the CUETools folder.
Note: AppData folders may be hidden but if you start typing the path directly into the navigation box of Windows file explorer...
korth
or
Thanks a lot, it works.
