Topic: Metadata padding and (NTFS) file system block/cluster size (Read 489 times) previous topic - next topic
I got curious and tried a web search without becoming any wiser:
Would it be straightforward for tagging software to pad to total file size = an integer number of file clusters?
(Yes it will take up an integer number of clusters sure, but you get my drift: if the file uses N clusters, then the padding is the maximum number of bytes that permits N.)
Is this even done routinely among applications that I even might be using?
Or are file systems more complex than that, with file system metadata etc making total size less predictable?
Re: Metadata padding and (NTFS) file system block/cluster size
Most tags are before the audio data, so you need your padding inside the file, which is not file system dependent then.
The program could round up from a minimum to 4 kB and account for the common block size. If you have large clusters now but copy your files to another disk, then the padding wouldn't be optimal anymore. Usually the amount of data stored in all files comprising an album is similar, either all have artwork or lyrics or they don't. So there is no use to having one with 2 kb and another with 32 kb. If you have small files with sound effects where this amount of padding data can add up to a significant fraction, you can afford to have zero or minimal padding in the first place.
That is precisely why you use padding in the first place.
I am sure you are able to calculate padding size = N*4096-(heading size + tags size + audio size) - if it really is that simple. Is it?
In order to pad tags before audio, you need to know exact audio size beforehand... but generally you cannot.
So, If you really want it, you need two-pass process. You encode whole audio first, then create new file, write tags and pad them, append audio copying from the first file.
I don't think it deserves.
Why not, if you already have a file?
If you are reading a stream and putting it to a file, then sure. But a typical tagger considers a file which has audio and maybe tags - and then you know audio, don't you?
As for whether it is warranted ... if some piece of software already has a functionality to reclaim padding, then yes it is.
Oh, I missed your point, sorry. I was considering of encoders.
When there is not enough room in the existing padding and a complete rewriting is required, then it might make some sense.
