Topic: Reverse engineering index.dat (Read 2232 times) previous topic - next topic
So I'm sure I'm not the only one that wants my playlists to update elsewhere with foobar being the point of truth for them.  To that ends I've been working with a friend (he'll probably show up) to reverse engineer the index.dat file so i can figure out what my playlist file name is.
This is necessary because the playlist filename will change, we think based on a hash of the file or track list.  We think this because adding a track changes it, removing it will change it back.
So here's what we have so far.
The first 24 bytes are header info:
    Header
        MagicSignature  35 47 5E 2A 60 1B 4B 4B 82 57 5C 8E 61 26 FD F6
        PlaylistCount   06 00 00 00
        LVEnabled       01 00 00 00         # LV is Library Viewer
Then here is an example of a standard playlist:
        Name Length     0C 00 00 00
        Name            43 6C 61 73 73 69 63 20 52 6F 63 6B
        SelectedTrack   DE 01 00 00
        MetadataLength  6D 00 00 00
                        04 00 00 00 # start of metadata
                        32 51 65 52 # playtime?
                        57 8F 56 4C 9A EE 17 52 5C 67 9A 5D
                        10 00 00 00
                        EB 4B 6B 7E E0 C6 61 40 BE 7F 2D 84 29 5F DE 8A
                        43 61 37 F4 79 4D E7 47 90 2E 10 A6 7B B5 57 0F
                        04 00 00 00
                        84 23 00 00
                        72 03 AA E3 5E 85 22 44 9A 5A 60 0B 13 38 5B B1
                        04 00 00 00
                        00 00 00 00
                        EE BC 6F 0C EC 8E 87 4F 8F E4 25 C2 3D 90 21 36
                        01 00 00 00
                        01 # end of metadata
        FileCount       01 00 00 00
        Filename        AA 59 31 90 6D DE 84 31 51 3D CB 1B 8E 40 22 21
And an example of a dynamic playlist
        Name Length     0F 00 00 00
        Name            4C 61 73 74 20 46 6F 75 72 20 57 65 65 6B 73
        Current Track   00 00 00 00
        MetadataLength  A9 00 00 00
                        32 51 65 52 57 8F 56 4C 9A EE 17 52 5C 67 9A 5D
                        10 00 00 00
                        AC EB 9F 75 13 8F D5 4E 92 DA EF C6 61 AF D8 D4
                        04 00 00 00
                        00 00 00 00
                        55 65 F1 82 CB 7A 8C 43 9C 4B 55 E1 D8 4D 15 64
                        3D 00 00 00
        ForcedSort      00 00 00 00
                        F4 53 B6 51 D7 A2 10 48 99 BD 06 72 47 12 17 5A
        QueryLength    21 00 00 00
        Query           25 6C 61 73 74 5F 70 6C 61 79 65 64 25 20 44 55 52 49 4E 47 20 4C 41 53 54 20 34 20 57 45 45 4B 53
                        00 00 00 00
                        04 00 00 00
                        00 00 00 00 # end of metadata
        FileName        62 A6 D9 1E 38 89 97 04 0A 0E D8 73 0C AF B6 E7
If all you care about is getting the filename from a playlist name, I have a script to do that here:
https://github.com/topherhead/FoobarIndexParser
Please don't judge my trash code  :))  :))  :))
But in the interest of completeness, I would like to try and get all the properties figured out.  There are several 16byte strings that are consistent between all playlists.  Even across computers.  Sorry there is probably some slop in the byte labels etc.  editing in a browser not super fun.
So anyone know what the other fields are in metadata?
Re: Reverse engineering index.dat
All objects are preceded by an identifier indicating what object it is. This identifier is always a GUID, which is 16 bytes.
Do we know a mapping of which guid goes to which object type?
I do not.
Next major update (after 1.6.x) goes full plaintext+sqlite for this.
Whatever work you do on reverse engineering current binary formats will be obsolete then.
Wow, that's exciting news! Will SQLite include only tags (manually edited metadata) or more/all metadata (codec, bitrate, replaygain et al.)?
lol!  welp, /thread I guess.  I'll just do it all over again when the update releases then.  But it will hopefully be much MUCH easier then.
