Topic: I tried to repair a CD-rip with EAC 1.5 (Read 406 times) previous topic - next topic
Did I succeeded? The CD has some scrtches, that's why some songs didn't rip well.
Original log created by EAC 1.5 with the errors:
Exact Audio Copy V1.5 from 20. February 2020
EAC extraction logfile from 16. April 2021, 21:48
Various Artists / Rock Against Bush, Vol. 1
Used drive  : ASUS    DRW-24B5ST   Adapter: 1  ID: 0
Read mode               : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 6
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Used output format              : User Defined Encoder
Selected bitrate                : 1024 kBit/s
Quality                         : High
Add ID3 tag                     : No
Command line compressor         : C:\Program Files (x86)\Exact Audio Copy\Flac\flac.exe
Additional command line options : -5 -V -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr1%" -T "ARTIST=%artist%" -T "TITLE=%title%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "ALBUMARTIST=%albuminterpret%" -T "COMPOSER=%composer%" %source% -o %dest%
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  2:07.20 |         0    |     9544
        2  |  2:07.20 |  1:39.67 |      9545    |    17036
        3  |  3:47.12 |  2:27.48 |     17037    |    28109
        4  |  6:14.60 |  2:29.07 |     28110    |    39291
        5  |  8:43.67 |  2:37.60 |     39292    |    51126
        6  | 11:21.52 |  2:10.03 |     51127    |    60879
        7  | 13:31.55 |  3:18.32 |     60880    |    75761
        8  | 16:50.12 |  3:22.58 |     75762    |    90969
        9  | 20:12.70 |  2:49.42 |     90970    |   103686
       10  | 23:02.37 |  3:13.18 |    103687    |   118179
       11  | 26:15.55 |  2:35.02 |    118180    |   129806
       12  | 28:50.57 |  2:23.38 |    129807    |   140569
       13  | 31:14.20 |  2:04.52 |    140570    |   149921
       14  | 33:18.72 |  3:14.58 |    149922    |   164529
       15  | 36:33.55 |  3:43.60 |    164530    |   181314
       16  | 40:17.40 |  2:30.30 |    181315    |   192594
       17  | 42:47.70 |  3:21.60 |    192595    |   207729
       18  | 46:09.55 |  2:38.30 |    207730    |   219609
       19  | 48:48.10 |  3:06.37 |    219610    |   233596
       20  | 51:54.47 |  3:25.20 |    233597    |   248991
       21  | 55:19.67 |  3:02.45 |    248992    |   262686
       22  | 58:22.37 |  2:58.38 |    262687    |   276074
       23  | 61:21.00 |  2:31.07 |    276075    |   287406
       24  | 63:52.07 |  2:31.13 |    287407    |   298744
       25  | 66:23.20 |  2:35.52 |    298745    |   310421
       26  | 68:58.72 |  2:04.05 |    310422    |   319726
Range status and errors
Selected range
     Filename E:\Bruno\Mi Música\Mis Rips\Various Artists - Rock Against Bush, Vol. 1.wav
     Suspicious position 0:50:17
     Suspicious position 0:50:20 - 0:50:22
     Suspicious position 0:50:26 - 0:50:27
     Suspicious position 1:02:45
     Peak level 100.0 %
     Extraction speed 1.1 X
     Range quality 99.6 %
     Test CRC 7996E45A
     Copy CRC 183858EF
     Copy finished
There were errors
AccurateRip summary
Track  1  accurately ripped (confidence 58)  [1BD14AFE]  (AR v2)
Track  2  accurately ripped (confidence 59)  [A35DA42A]  (AR v2)
Track  3  accurately ripped (confidence 58)  [FB79C9EA]  (AR v2)
Track  4  accurately ripped (confidence 58)  [637C4243]  (AR v2)
Track  5  accurately ripped (confidence 58)  [EA112CEB]  (AR v2)
Track  6  accurately ripped (confidence 58)  [8870BEB1]  (AR v2)
Track  7  accurately ripped (confidence 58)  [DBCA982E]  (AR v2)
Track  8  accurately ripped (confidence 59)  [A88A4AD5]  (AR v2)
Track  9  accurately ripped (confidence 58)  [87F4007C]  (AR v2)
Track 10  accurately ripped (confidence 58)  [CFBF81A3]  (AR v2)
Track 11  accurately ripped (confidence 58)  [D72015FD]  (AR v2)
Track 12  accurately ripped (confidence 57)  [BC1DA422]  (AR v2)
Track 13  accurately ripped (confidence 58)  [F61D1459]  (AR v2)
Track 14  accurately ripped (confidence 58)  [1828BD42]  (AR v2)
Track 15  cannot be verified as accurate (confidence 66)  [B74E7CFF], AccurateRip returned [C82DF382]  (AR v2)
Track 16  accurately ripped (confidence 58)  [7BB484B4]  (AR v2)
Track 17  accurately ripped (confidence 58)  [1559CF0E]  (AR v2)
Track 18  accurately ripped (confidence 59)  [82024DD9]  (AR v2)
Track 19  cannot be verified as accurate (confidence 66)  [2DF35254], AccurateRip returned [4D5FBE97]  (AR v2)
Track 20  accurately ripped (confidence 57)  [0FE52430]  (AR v2)
Track 21  accurately ripped (confidence 56)  [47F81514]  (AR v2)
Track 22  cannot be verified as accurate (confidence 66)  [BBC1AD62], AccurateRip returned [D245CFEE]  (AR v2)
Track 23  cannot be verified as accurate (confidence 66)  [8D02EB4C], AccurateRip returned [835F3163]  (AR v2)
Track 24  accurately ripped (confidence 58)  [5B1A2583]  (AR v2)
Track 25  accurately ripped (confidence 58)  [E3EEAED0]  (AR v2)
Track 26  accurately ripped (confidence 57)  [E98CFD84]  (AR v2)
22 pista(s) extraidas con precisión
 4 pista(s) no puede ser verificada como precisa
Some tracks could not be verified as accurate
End of status report
---- CUETools DB Plugin V2.1.6
[CTDB TOCID: SgMv28hQhGAe8OA_wEWkQuSkTok-] found
Submit result: insufficient quality
Track | CTDB Status
  1   | (184/185) Accurately ripped
  2   | (184/185) Accurately ripped
  3   | (181/185) Accurately ripped
  4   | (183/185) Accurately ripped
  5   | (185/185) Accurately ripped
  6   | (185/185) Accurately ripped
  7   | (185/185) Accurately ripped
  8   | (184/185) Accurately ripped
  9   | (185/185) Accurately ripped
 10   | (185/185) Accurately ripped
 11   | (184/185) Accurately ripped
 12   | (184/185) Accurately ripped
 13   | (183/185) Accurately ripped
 14   | (182/185) Accurately ripped
 15   | (166/185) Differs in 11 samples @01:44:71,01:55:26,02:01:65,02:10:74,02:23:28,02:24:52
 16   | (183/185) Accurately ripped
 17   | (183/185) Accurately ripped
 18   | (181/185) Accurately ripped
 19   | (166/185) Differs in 408 samples @01:28:27,01:29:41-01:29:42,01:30:02,01:30:22,01:30:74,01:31:71,01:32:14,01:32:68,01:33:46,01:33:64,01:34:25-01:34:26,01:34:43-01:34:44,01:35:04,01:35:58,01:36:73,01:38:30-01:38:31,01:38:48,01:38:66,02:31:55,02:33:68,02:35:62-02:35:63
 20   | (180/185) Accurately ripped
 21   | (181/185) Accurately ripped
 22   | (166/185) Differs in 1 samples @01:02:04
 23   | (166/185) Differs in 18 samples @01:24:35-01:24:36
 24   | (183/185) Accurately ripped
 25   | (181/185) Accurately ripped
 26   | (174/185) Accurately ripped
If you are sure that your rip contains errors, you can use CUETools to repair it.
==== Log checksum 1E73DA96A73EE82E02485FB3353539BB3697D8A82467600DF8FBB376560B1355 ====
I repaired with CueTools, but when I pressed "Go" I had this 4 options, I selected the bottom one, don't kow why. I dont know which os is the best option.
https://ibb.co/h14QcFQ
When the repair ended, the program showed this:
[CUETools log; Date: 16/04/2021 22:19:08; Version: 2.1.8]
CUETools DB: corrected 438 errors.
[AccurateRip ID: 00405dd1-04c4e36e-6810a71a] found.
Track   [  CRC   |   V2   ] Status
 01     [e86e30d0|1bd14afe] (065+058/123) Accurately ripped
 02     [a6ae02a1|a35da42a] (065+059/124) Accurately ripped
 03     [f888e8ae|fb79c9ea] (065+058/123) Accurately ripped
 04     [f8da517d|637c4243] (065+058/123) Accurately ripped
 05     [1b45e638|ea112ceb] (065+058/123) Accurately ripped
 06     [a04c9874|8870beb1] (065+058/123) Accurately ripped
 07     [26ebeef7|dbca982e] (065+058/123) Accurately ripped
 08     [3a9e030e|a88a4ad5] (064+059/123) Accurately ripped
 09     [324e7824|87f4007c] (066+058/124) Accurately ripped
 10     [2aebd841|cfbf81a3] (067+058/125) Accurately ripped
 11     [a4094dc6|d72015fd] (065+058/123) Accurately ripped
 12     [6917b4df|bc1da422] (067+057/124) Accurately ripped
 13     [e20073bc|f61d1459] (066+058/124) Accurately ripped
 14     [baedfef2|1828bd42] (066+058/124) Accurately ripped
 15     [c82df382|da54bcee] (066+059/125) Accurately ripped
 16     [e4abc719|7bb484b4] (066+058/124) Accurately ripped
 17     [8ffb5994|1559cf0e] (066+058/124) Accurately ripped
 18     [dfb31b7a|82024dd9] (066+059/125) Accurately ripped
 19     [4d5fbe97|284d5a76] (066+058/124) Accurately ripped
 20     [8ccd6f2b|0fe52430] (066+057/123) Accurately ripped
 21     [1f7652e7|47f81514] (067+056/123) Accurately ripped
 22     [d245cfee|7ee07176] (066+058/124) Accurately ripped
 23     [835f3163|1f04bf7b] (066+057/123) Accurately ripped
 24     [c79a04f1|5b1a2583] (066+058/124) Accurately ripped
 25     [f250191e|e3eeaed0] (064+058/122) Accurately ripped
 26     [90c3a764|e98cfd84] (064+057/121) Accurately ripped
Track Peak [ CRC32  ] [W/O NULL] [  LOG   ]
 --  100,0 [D294F7B3] [47EBF825] [183858EF]
 01   90,1 [7FC1BB31] [906CE2C2]
 02   99,8 [8E427629] [D8A76D3F]
 03   99,3 [0472E554] [FB0C0C50]
 04  100,0 [2E0A7C3A] [2E9B6FF6]
 05   98,8 [1FF1427F] [2064B20E]
 06   98,8 [AFF09A19] [621D0447]
 07   84,1 [D579D68F] [372E7C0D]
 08   98,8 [3256F089] [1E1D2BDB]
 09   98,8 [BD7CADFB] [FFC70592]
 10   98,8 [BA7EAF30] [D3D253AE]
 11   98,8 [CF0B8462] [F83AF111]
 12  100,0 [F1460B2C] [D5007DD5]
 13   99,3 [50643B8E] [7CDCA8A9]
 14  100,0 [ED9FC2B7] [01BA04E0]
 15   98,8 [96373D7D] [739A2188]
 16   98,8 [C8010647] [5177535C]
 17   99,1 [8E8781F8] [13EC3DB9]
 18   56,9 [9791BE32] [6F81CD83]
 19  100,0 [D3ED8194] [B34D7213]
 20   94,2 [760DC791] [58C232C4]
 21   98,8 [1624DFB1] [9A5B5E7A]
 22   91,2 [32E99DF8] [C7B5C686]
 23   98,8 [3E01FE34] [F6431742]
 24   98,8 [5F47419D] [75CF4BAD]
 25   98,8 [5B91C820] [418033BC]
 26   81,2 [B39E87A3] [1E98B276]
Can I check or something if finally the rip is 100% correct? How can I know which is the best match when repairing of those 4 options?
Mod Edit: Add thumbnail of image.
Re: I tried to repair a CD-rip with EAC 1.5
Repaired.
You can run Verify. That will give you the full log report including the CTDB section.
All 4 tracks were repaired by the same recovery record. The log doesn't show you had any other choices.
Edit: Found the picture. Those 4 options were for metadata. To keep original metadata, untick 'Edit Tags' when repairing.
http://cue.tools/wiki/CUETools_Settings#.288.29_Mode_.7Bsection.7D
korth
So this album only had one option to correct it and the 4 results are just for metadata? If someone ripped the CD with different results (because different manufacturing CD or something) where it shows?
How can I open the .accurip file that gets created when repairing?
You could enable 'Detailed log' on the 'Advanced Tab' of settings
http://cue.tools/wiki/CUETools_Advanced_Settings:_Advanced#CTDB
the results of rips as a whole CD will be added to the CUETools log (.accurrip file)
http://cue.tools/wiki/CUETools_log#Comparison_of_this_rip_.28whole_disc.29_to_CTDB_records
Note: Due to an issue with early versions of the CTDB EAC Plugin, it is recommended to avoid doing a repair when the CTDB shows only 1/x. (where 1 is the number of rips in the database that match that CTDBID and x is the total number of rips for all CTDBIDs)
http://cue.tools/wiki/CTDB_EAC_Plugin#Known_issues
each CTDBID is a different rip result and each CTDBID that has more than 1/x rips may be due differences in the CD that was ripped (different manufacturing, a manufacturing flaw, etc.).
You can also view the top 10 for the layout of your CD on the database site.
Copy the CTDB TOCID from the EAC extraction logfile
and add that to
http://db.cuetools.net/top.php?tocid=
http://db.cuetools.net/top.php?tocid=SgMv28hQhGAe8OA_wEWkQuSkTok-
The Cf column to the far right is the number of rips that match each CTDBID.
The .accurip file is a text file that can be opened with a text editor such as 'notepad'.
korth
