Topic: foobar2000 shows error when trying to check for any update (Read 370 times) previous topic - next topic
I am using foobar2000_v1.6.5 on windows 7 and recently it does not allow me to check for new versions, component updates or download lyrics and shows me the following error: "Network authentication error (80090302)".
I have seen another similar error reported previously in this forum but the identifier is different: "Network authentication error (80090326)", even so I tried the solutions indicated there, but they do not work for me.
If you can help me and give me a prompt answer with this problem I will be forever grateful.
Re: foobar2000 shows error when trying to check for any update
Please confirm that you have executed the file attached to the post here and rebooted your PC: https://hydrogenaud.io/index.php?topic=118821.msg980059#msg980059
@sveakul I have already executed the attached file and now the problem with the update searches has been corrected. THANK YOU VERY MUCH for your help.
But on the other hand Lyric Show 3 still doesn't work, it only shows the ones that are already there but doesn't perform any new search. I have tried deleting the lyrics that I am sure exist and that I had previously downloaded, but now when I try to perform a new search it does not get anything.
Most of the "stock" search choices in LSP-3 don't work anymore because the sites have changed the search method.  Try installing the foo_multisource plugin .31 from the link within the post here: https://www.reddit.com/r/foobar2000/comments/kl1ipj/lyric_show_panel_3_lyrics_from_genius_musixmatch/?sort=new .  Then, add all the sources starting with "Multi DB" from the LSP-3 "available sources" window to the "search order" window.
You also should get foo_lrc_metalarchives plugin and install the same way if you have anything remotely resembling metal in your collection:  https://hydrogenaud.io/index.php?action=dlattach;topic=108084.0;attach=11999
THANK YOU!!! now the problem has been corrected and I can download and view the lyrics.
