Topic: Replacing the file 'flac.exe' in the 'encoders' directory (Read 317 times) previous topic - next topic
Hi there!
I would like to know if I can replace the executable 'flac.exe' in the 'encoders' directory of foobar2000 (portable version) with the one available on the 'RareWares' website.
And, if so, would the substitution be made only by the option 'bundle', which contains the said executable?
Thanks in advance.
Re: Replacing the file 'flac.exe' in the 'encoders' directory
You can do whatever you want with the "encoders" directory. Just don't expect the installer not to wipe it out when it installs its own flavor.
OK, thanks for the info!
What's the difference between the executable (flac.exe) and the 'libFLAC' file?
libFLAC is the encoder and decoder core component of both flac.exe, and foobar2000's built-in decoder. You only need to supply command line encoders for foobar's converter.
Thank you very much!
Just one more question, please:
What is 'metaflac.exe', when and where I must use it?
Sorry and thanks in advance.
OK, thank you very much!
