Topic: 1.6.5b4 - Replaygain bug switching between true peak scan oversample settings (Read 229 times) previous topic - next topic
I've been playing around with the Replaygain scanner page in the preferences in the latest beta and found this very minor odd bug that effects changing between the [auto Xx oversample] options.
To reproduce:
Enable true peak scan and leave the drop down box as [auto 2x oversample] and click apply. Before closing the preferences change the auto oversample to 8x (notice that the apply button is still ghosted) and then click ok to exit the preferences. Open the preferences again and it will be set back to 2x again.
Workaround:
Change the oversample setting and then disable and reenable true peak scan and click apply.
Core (2021-03-29 14:25:46 UTC)
    foobar2000 core 1.6.5 beta 4
foo_albumlist.dll (2021-03-29 14:25:02 UTC)
    Album List 1.6.5 beta 4
foo_cdda.dll (2021-03-29 14:25:00 UTC)
    CD Audio Decoder 1.6.5 beta 4
foo_converter.dll (2021-03-29 14:25:08 UTC)
    Converter 1.6.5 beta 4
foo_dop.dll (2020-02-02 04:28:14 UTC)
    iPod manager 0.7.2
foo_dsp_eq.dll (2021-03-29 14:24:56 UTC)
    Equalizer 1.2.2
foo_dsp_std.dll (2021-03-29 14:24:56 UTC)
    Standard DSP Array 1.6.5 beta 4
foo_facets.dll (2011-08-18 20:06:16 UTC)
    Facets 1.0
foo_fileops.dll (2021-03-29 14:25:04 UTC)
    File Operations 1.6.5 beta 4
foo_freedb2.dll (2021-03-29 14:25:08 UTC)
    Online Tagger 0.8
foo_input_std.dll (2021-03-29 14:25:40 UTC)
    FFmpeg Decoders 4.3.1
    Standard Input Array 1.6.5 beta 4
foo_out_wasapi.dll (2020-12-30 00:08:46 UTC)
    WASAPI output support 3.4
foo_rgscan.dll (2021-03-29 14:25:14 UTC)
    ReplayGain Scanner 1.6.5 beta 4
foo_simplaylist.dll (2011-08-18 20:01:36 UTC)
    SimPlaylist 1.0
foo_ui_std.dll (2021-03-29 14:25:16 UTC)
    Default User Interface 1.6.5 beta 4
foo_unpack.dll (2021-03-29 14:25:22 UTC)
    ZIP/GZIP/RAR/7-Zip Reader 1.6.5 beta 4
foo_wave_minibar_mod.dll (2020-11-22 05:12:22 UTC)
    Waveform Minibar (mod) 1.0.43
Re: 1.6.5b4 - Replaygain bug switching between true peak scan oversample settings
Fixed for the next update, thanks for reporting.
Fix included in beta 5.
