Topic: Switch to Disable Corrupted installation Warning for old plugins (Read 1317 times) previous topic - next topic
I use older Replay Gain Scanner component for consistency with the rest of my collection. Newer Foobar warns about it and exit. There should be a way to circunvect or disable that checking, maybe with a switch on launch under userrs responsability. It's annoying to have to use newer plugins if desired behaviour isn't user wish...
Re: Switch to Disable Corrupted installation Warning for old plugins
What version of Foobar2000 are you using?
The latest beta version has an option to switch it back to the classic replaygain so the plugin shouldn't be needed.
