Poll
What lossy format(s) do you use on a *regular* basis?
AAC or HE-AAC v1/v2 (.m4a, .aac…)
LossyWAV + lossless (.lossy.flac, .lossy.wv, .lossy.tak…)
MP3 (.mp3)
Musepack (.mpc)
Ogg Vorbis (.ogg)
Opus (.opus)
WavPack Lossy/Hybrid (.wv)
xHE-AAC (USAC)
I don't really use any lossy codec on a regular basis
Voting closes: 2022-01-02 02:34:16
Topic: 2021 Format poll [Lossy Formats] (Read 2205 times) previous topic - next topic
Re: 2021 Format poll [Lossy Formats]
I don't really use any lossy codec explicitly on a regular basis.  While driving I use Tidal on phone (hooked to car's bluetooth) which automatically switches from FLAC to AAC when connected to metered 4G.
Possible: https://linkto.run/p/QS6X98RC
Added notice:
The results cannot be verified but given that this forum is not known to attract spammers or fanboys, the results could probably be used.
Nice. Voted there as well.
Me too, I keep my music in ISO BFF, encoded in ALAC (lossless, float32, so I could not keep it in FLAC), I pay iTunes Match which allows me to hear any song in my library in AAC by matching the songs present and uploading of songs not present in their servers. But the contents are not only these, when I send I send a voice message I use Opus, I keep my speech recordings in AAC, when I listen to television I listen to MPEG 1 - Layer 2, I hear the radio in analogue or HE-AAC , If I watch a video on YouTube I receive the audio in AAC (in Opus with Linux), if I listen to a podcast it is almost always in AAC or MPEG 1 - Layer 3, in a nutshell I no longer decide anything except how to keep my music, which in the past I kept in uncompressed AIFF. For work I can choose to keep the recordings in an ISO standardized format.
What, does ALAC support that? (It very well could ... refalac doesn't.)
MP3 ; at least as of very recent memory...
...since I got a hold of a 'AGPTEK-U3(8GB)' device (for about $25) on Mar 18th 2021 as that only supports MP3/WMA/WAV, which pretty much means MP3 since WAV files are too large and no one uses WMA. I am using LAME V5 (130kbps) on pretty much all of my music I put on it as it's a efficient bit rate with MP3 and sound quality is good enough in general (although I could put all my MP3's at V0 (245kbps) if I wanted to. but at V5, it helps ensure that 16GB MicroSD card will be plenty for years to come).
that AGPTEK-U3 device has a MicroSD card slot and claims it supports up to 128GB (which would be major overkill for me unless one is using WAV files on it). I currently got a 16GB MicroSD card in it which is what I am using to store my music on as that will easily last me for the foreseeable future (especially since I have tweaked my collection a bit to remove most of the 'filler' songs on albums to just the songs that stand out for me (or thereabouts) as this further frees up space and raises the average quality of the songs I got on my device).
but at this point in time Opus/AAC(AAC-LC)/MP3 (in that order) are all that's worth considering for lossy formats when factoring in the best lossy format along with widely supported formats in my opinion and the general poll results are pretty much inline with this mindset. so MP3 would be my choice only if a device fails to support Opus/AAC(AAC-LC).
but with that said... I did use MPC a little here and there over the years on my Sansa e200 series device (running 'Rockbox') which I pretty much retired recently (it will still power on and run a while but you can tell the battery is so-so though and you have to recharge it a bit more often than I would like to) since it's hard to find quality replacement batteries which is why I bought the AGPTEK-U3(8GB) device since it uses a standard single AAA battery. I use rechargeable NiMh (seems to get around 12 hours of battery life on a single 800mAh battery (which is actually 800mAh according to my Powerex C9000 charger)) and ill never have to worry about the device being pretty much crap due to lack of quality replacement batteries (the AGPTEK-U3 device is like those old MP3 players from the 2000's (navigating the interface is a bit slower etc but you can select folders to play music from which was a critical feature I needed the device to have) but, unlike those, it has plenty of storage space). I just hope the device is reliable enough as I hope I can get at least 10+ years of use out of it as I am not a type of person who buys a device and disposes it in a few years or so like many do. the Sansa e200 series device was a solid digital audio player but the battery became it's biggest flaw as time passed. o well, I had the Sansa e200 series player since I think June 2008 and I got quite a bit of use out of it over the years.
but when I am on my computer I generally play the lossless (FLAC) files instead of lossy ones through Foobar2000. but when I am on-the-go is when ill use (at least as of very recently) MP3 on that AGPTEK-U3(8GB) device. but prior to getting that recently I was using MPC on the Sansa e200 running Rockbox at the 'standard' 170kbps setting mostly because I think that was a bit better on battery than AAC is and being the e200's battery is so-so, I was trying to squeeze as much battery life out of it as possible. so I had to use either MPC or MP3 it seems from that aspect otherwise I would have probably went with AAC(AAC-LC) at 96kbps (or 128kbps MAX).
p.s. but whether I would recommend that AGPTEK-U3 device or not largely boils down to whether it's built-to-last or not (as it's a cheap china made device as it might last for many years but it may not.). if it lasts for a long time I would definitely say it's a good buy for someone looking for a basic/cheap MP3 player for on-the-go music as it's light in weight and good battery life on a single AAA at about 12 hours on a single 800mAh NiMh battery (they officially claim 'up to 10 hours' on battery life which might be true depending on the battery used, but in my case, while I did not measure it precisely, I had to be around 12 hours or so from a quick estimated amount of use when testing it after I got it. NOTE: the device has 4 battery bars and I noticed once the last battery block is shown (like the device is battery is close to empty) you got about 1 hour left before the battery is dead on my NiMh battery test, which is nice since it gives one ample time to use it and serves as a warning to re-charge it soon once you see the 1 battery block left on screen). I use the 'Rock' sound preset which is definitely better than the default one.
For music I suggest...
1)Opus @ 64kbps or 96kbps.
2)AAC (Apple or FhG(Winamp)) @ 96kbps.
3)MP3 (LAME) @ V5 (130kbps). NOTE: I am using MP3(V5) on AGPTEK-U3(8GB) as of Mar 18th 2021.
I actually use wma pro more than ogg vorbis. Since that was taken off as an option on these pulls, I went with ogg because 8.5% of my computer library is ogg. My mobile is all wma pro though.
(They really should have been treated as different options. Most things that can play wma can't play wma pro.)
Processed audio in java and python.
Reply #30
I am surprised someone around here uses WMA as it seems like a format barely anyone uses at this point in time(?). hell, Foobar2000 (which seems to be a popular audio playback/conversion program around here) does not even have a WMA preset option in the 'Convert' screen which probably says a lot about WMA.
I would assume MP3/AAC/Vorbis(ogg)/Opus (and possibly some others) are more popular/used than WMA at this point in time. so in my opinion... I would seriously consider re-ripping from your lossless files to another more common lossy format. unless of course you don't have all of your collection in lossless format then this might not be a real option.
Well, it works on GoneMad Music player. That's all I need. I tried Vorbis, but when I rated a song, it corrupted the file. They have since re-wrote the whole app and probably fixed that issue, but hey, I'll probably hold out using wma pro until its bitter end.
I kinda agree - it only needs to work on that player I use. Because lossy files which I encode myself, are disposable.
It is even a point to have it in a format I don't use for anything else. I chose opus, but I should maybe even have considered Musepack.
(But WMA Pro? Nah, has same file suffix as ordinary WMA.)
Reply #33
I see. but I took a quick look online and it appears that's a app for a android smart phone(?). if so, I would probably just start using the Foobar2000 mobile app instead since it will support Opus (and all of the other more common formats like MP3/AAC etc) which is what I would opt for anyways since you can probably use 64kbps with the Opus format on a smart phone, especially if your tight on space and have a decent sized music collection. but if you prefer to stick to more standardized formats then naturally MP3 or AAC would be your safest bet. but putting those aside, Opus looks like the best, especially of the modern lossy formats.
Reply #34
GoneMAD player supports all the formats in the Poll.  I'm uninstalling Poweramp player.
OpusFLAC or OpusWAV  🤔
Reply #35
Haha, funny you should say that. I also started with Poweramp player too.
I would probably just start using the Foobar2000 mobile app instead...
Foobar2000 mobile does not do play counts. GoneMad meets and exceeds the bar set by the Creative Labs Zen Vision: M player. (Maybe it doesn't play movies.... but that's the only thing.) In fact, most dedicated mobile music players and music player apps, fall pretty short when compared to standards set by mobile music players from back in 2005.
Reply #36
I use exhale v1.1.0-c71ec480-Stable_Win_GCC102 with preset 2 on some songs that required lower bitrate, at the moment is only a list calculated in ytm, the rest is opus 128 kbps not converted by me (not videoclip), or flac when i need dynamic range (i have like six new).
For preset 1 i prefer v.1.0.3-41751381: it gives consistent results. 18/05/2020, opus 64 kbps sounds mono to me, or fake stereo,
only x he aac sounds stereo to me. A good SBR is exhale-develop-1.1.0rc4-c71ec480_x64 at a-b.  At preset 4 i used exhale-1.0.8-39dc1852-RC_Win_GCC102 but i should've used exhale-1.1.2-193dc268_(BETA) as it has better temporal resolution, but i prefer to avoid preset 4 and only use preset 2.  I'm not an expert. I'll stop here, these are the one i usually use.
Now i will vote opus.
Reply #37
I use Opus at 128 kbps for music and 32 kbps for podcasts on all my devices (android phone, rockbox dap, computer). It's open source, sounds great at low bitrates and is well supported at this point. 96 kbps is pretty much always transparent for me in ABX tests, I just use 128 kbps to be on the safe side.
