Topic: Is 2.1.8 a stable version? (Read 817 times) previous topic - next topic - Topic derived from CUETools 2.1.8 window.
2.1.8 is a stable version?
"Always account for the change."
Re: Is 2.1.8 a stable version?
Thanks for the answer. I have portable version. To update I have to move all contents from zip in the folder of previous version?
No official announcement is made regarding v2.1.8 yet.
But it's listen as 'Current release' on the Download page @  http://cue.tools/wiki/CUETools_Download
@c72578
built 2.1.8 and marked the release as 'Stable'.
I excluded the word 'Stable' when I added the link to the wiki's download page. A beta or nightly version isn't offered prior to release so testing begins with the release itself. In the past a release was tagged 'for testing purposes' and not declared "Stable" until tested by the users without reports of major issues. I consider 2.1.8 a 'test build' (for now).
I suggest starting fresh (copy contents of zip to a new folder) and create a new settings file (\CUE Tools\settings.txt). Note: The encoder and decoder settings are being stored differently now.
korth
Can I copy and past previous settings.txt after installed new version?
As I said, the encoder and decoder settings are being stored differently now. I haven't fully tested 2.1.8 using an old settings file to see if settings.txt is properly updated.
older
=</CUEConfigAdvanced>
ExternalEncoder0Name=cuetools
ExternalEncoder0Extension=wav
ExternalEncoder0Lossless=1
ExternalEncoder0Settings=<WAVWriterSettings />
ExternalEncoder1Name=cuetools
ExternalEncoder1Extension=m4a
ExternalEncoder1Lossless=1
ExternalEncoder1Settings=<ALACWriterSettings>
=  <EncoderMode>5</EncoderMode>
=</ALACWriterSettings>
ExternalEncoder2Name=FLACCL
ExternalEncoder2Extension=flac
ExternalEncoder2Lossless=1
ExternalEncoder2Settings=<FLACCLWriterSettings>
=  <EncoderMode>8</EncoderMode>
=  <GPUOnly>false</GPUOnly>
=  <DeviceType>CPU</DeviceType>
=</FLACCLWriterSettings>
ExternalEncoder3Name=cuetools
ExternalEncoder3Extension=flac
ExternalEncoder3Lossless=1
ExternalEncoder3Settings=<FlakeWriterSettings>
=</FlakeWriterSettings>
2.1.8
Advanced={
=  "encoders": [
=      "$type": "CUETools.Codecs.WAV.EncoderSettings, CUETools.Codecs"
=      "$type": "CUETools.Codecs.ALAC.EncoderSettings, CUETools.Codecs.ALAC",
=      "EncoderMode": "5"
=      "$type": "CUETools.Codecs.FLACCL.EncoderSettings, CUETools.Codecs.FLACCL",
=      "EncoderMode": "8"
=      "$type": "CUETools.Codecs.Flake.EncoderSettings, CUETools.Codecs.Flake",
see also https://hydrogenaud.io/index.php?topic=116743.0
korth
Ok, I preferred a clean installation with last hotfix. Tried to split an image with zero problems. :) Thanks Korth! ;)
