Topic: Beginner playback_state question (Read 324 times) previous topic - next topic
Hi, I am trying to implement the following feature: When starting to play a song, it starts at a random part in the song. This is similar to this old Preview component https://skipyrich.com/wiki/Foobar2000:Preview except I want to be able to accept random values, not just a fixed second/percentage value.
So first of all, I took the foo_sample component and am just modifying it to test things out as I am very new. I tried implementing my feature within a context menu command, which works perfectly.
Code: (myPlaybackFunction) [Select]
playback_control::ptr pbc = playback_control::get();
double songLength = pbc->playback_get_length();
double randomTime = rand() % (int)songLength;
pbc->playback_seek(randomTime);
However, I want to be able to do this automatically (eventually add a toggle feature too). So I added this code into playback_state.cpp (CPlaybackStateDemo class). This is the big part which is confusing me. I have tried putting the above code (and some variants) into:
  • on_playback_starting, on_playback_new_track, on_playback_pause, etc.
  • update
  • a function, and then using
    void on_playback_pause(bool p_state)
    update();
    std::function<void()> test1 =
    myPlaybackFunction();
    fb2k::inMainThread(test1);
but can't seem to get anything to work. From what I can tell, CPlaybackStateDemo inherits from play_callback_impl_base which registers itself on construction, yet I can't seem to get any calls to do anything. To be honest I have no idea where to go from here. Not sure if I'm missing something simple or if I need a much larger understanding of the foundation for this. I'm new to C++ (mostly a C# background). Any help would be appreciated, thanks.
P.S. I use Visual Studio to compile everything and was wondering if there was a nice way to debug. I've been building and then using the component, testing everything manually.
Re: Beginner playback_state question
I think that foo_sample code will only run when the dialog is open. You want your own class derived from play_callback_static
class MyClass: public play_callback_static
public:
    uint32_t get_flags() override
         // take care to return the flags for the callbacks you intend to use.
   // all other overrides go here
FB2K_SERVICE_FACTORY(MyClass);
As for debugging, I generally setup a junction from the VS output folder to a folder inside the user-components folder of a portable install. From an administrator command prompt, I might do something like..
mklink /D z:\foobar2000\profile\user-components\foo_sample z:\git\foobar2000-sdk\foobar2000\foo_sample\Release
Then inside VS itself, to to the Properties of your project>Debugging>Command and set it to the foobar instance above - in my case z:\foobar2000\foobar2000.exe
Also, make sure the project is set as the "startup project", Right click in solution explorer>set as startup project.
That did it! The debug tip also helped a bunch and I will be working toward my toggle now. Thank you very much!
