Topic: Split large FLAC file to single flac files, what level should I use? (Read 309 times) previous topic - next topic
Hi everybody,
I have converted my entire CD collection to FLAC files. I choosed the option to have one single FLAC file for each CD with a CUE file.
Now I want to cut some tracks as FLAC file bit without loosing quality. So the single flac file shoud by equal to the track in the large flac file.
I have read that I can convert the track to FLAC again and the quality remains the same. Can someone confirm this?
If this is, what compression level should I use in the encoder settings in Foobar2k?
Re: Split large FLAC file to single flac files, what level should I use?
I doesn't matter what level of flac compression you use there is no difference in quality. I always use level 8. It takes only slightly longer to write the file but it gives you the smallest file size.
