Topic: How do I see the bpm track information? (Read 507 times) previous topic - next topic
Is there a way to enable track information during playback?
Re: How do I see the bpm track information?
Nothing?
You've got to Google for it.
  • Right click on any bar title
  • Select Columns
  • Select More ...
  • In Custom Columns, select Add New
  • Change <name> by BPM or the name you want
  • In the Pattern column place %BPM%
  • Click Ok
  • Select Columns
  • Select BPM or the name you set
wagner reatto
  • Select Columns
  • Select More ...
  • Click Ok
  • Select Columns
Thank you but I meant Foobar2000 for mobile.
This is, after all, the mobile subforum.
You'll have to wait for Peter to notice your feature request. And you may want to specify. Is this tagged information? Or do you want a BPM detector as well?
Thanks for your answer kode54. I think File format, Sample rate, Bits per sample and Bitrate would be nice!
Ah, technical info on the file. That could be useful, and also optional.
It would be great to have these tags available for custom skins!
