Topic: foobar2000 ftp server on iphone (Read 224 times) previous topic - next topic
i had just installed latest foobar2000 mobile to my iphone, was trying to setup ftp server in order to transfer mp3.
i cannot turn on the ftp server while connect to local network, but if i connect to LTE which is data plan, i can turn on the ftp server.
Can someone please help? What could be the issue?
Thanks,
Re: foobar2000 ftp server on iphone
Anyone has the same issue and would you please share the solution?
never mind, i figure this out. This has something to do with your local network setting.  If you choose to use non-default DHCP setting, you will have issue.
