Topic: Issue with $replace function in "File name pattern" of Foobar's File Operations (Read 287 times) previous topic - next topic
This issue happens to me only with tracks containing a vertical bar '|' [$char(124)] in their %artist% or %title%.
Steps to reproduce :
1. Choose a track for a test. Set the title to something like 'xxxx | yyyy'
2. right-click a track > File Operations > Rename To > ... > "File name pattern" > $replace(%title%,$char(124),~)
Expected Result : file Destination : xxxx ~ yyyy
Actual Result : file Destination : xxxx _ yyyy
Win 7 x64
Foobar 1.6.4
Thanks in advance.
Re: Issue with $replace function in "File name pattern" of Foobar's File Operations
Not foobar issue.
You can't write ~, | or any illegal character as file name on windows system.
Edit;
However, there is an option you can try, at advanced preferences / tools / file operations / check modern (unicode) replacement of illegal file name characters
foobar2000 plays music
~ is a fully legal character. Just try!
Sorry I wasn't aware of that. Then this might indeed be issue.
