Topic: PSF file playback error: "Unable to open item for playback (Object not found)" (Read 277 times) previous topic - next topic
Hi! For a few weeks now, whenever I try to play a PSF file I get a playback error saying "Unable to open item for playback (Object not found)". The folder is unzipped, the .psflib files are in the same folder as the PSFs, I have vgmstream and Game Emu Player installed, among other components.
I've never encountered this issue before, and I have absolutely no idea what's causing it. Please help!
Re: PSF file playback error: "Unable to open item for playback (Object not found)"
If it's not missing the component (foo_psf) then check the player console and verify something isn't otherwise missing from the set. Also check that VGMStream isn't set to handle "common" extensions, as it definitely does not support PSF files.
H̶i̶g̶h̶l̶y̶ ̶E̶x̶p̶e̶r̶i̶m̶e̶n̶t̶a̶l̶ ̶i̶s̶ ̶i̶n̶s̶t̶a̶l̶l̶e̶d̶,̶ ̶t̶h̶e̶ ̶p̶l̶a̶y̶e̶r̶ ̶c̶o̶n̶s̶o̶l̶e̶ ̶d̶o̶e̶s̶n̶'̶t̶ ̶s̶h̶o̶w̶ ̶a̶n̶y̶ ̶e̶r̶r̶o̶r̶s̶,̶ ̶t̶h̶e̶ ̶"̶e̶n̶a̶b̶l̶e̶ ̶c̶o̶m̶m̶o̶n̶ ̶e̶x̶t̶s̶"̶ ̶b̶o̶x̶ ̶i̶n̶ ̶V̶G̶M̶S̶t̶r̶e̶a̶m̶ ̶i̶s̶ ̶u̶n̶c̶h̶e̶c̶k̶e̶d̶,̶ ̶I̶'̶m̶ ̶a̶t̶ ̶a̶ ̶c̶o̶m̶p̶l̶e̶t̶e̶ ̶l̶o̶s̶s̶.̶
Nevermind, somehow it works now. I already tried reinstalling foo_psf yesterday, and it did nothing, but now SOMEHOW it works. Oh well.
