Topic: Cue Sheet utility issue (Read 126 times) previous topic - next topic
Hello,
Currently using Foobar 1.6.4 on 2 different PCs running Windows 10. Both Foobar installations are 1.6.4 with the exact same set of components installed and no updates required on either PC for the components.
Issue:
1)an ISO file is on a networked NAS drive which did not come with a CUE sheet
2)I load the ISO file and 10 tracks appear with generic information. I added track titles, album, date and artist manually on all of the tracks
3)I select all tracks then use the Utility|Save as cuesheet
4)the Cue sheet is saved in the same folder as the ISO, all works fine on PC#1
5)On the second PC pointing to the exact same location. I load the cuesheet into PC#2. All metadata is populated correctly however no tracks play and I receive this error on each of the tracks:
"Unable to open item for playback (I/O error):
"O:\Music\DTS and Quad FLAC\Artist\ LP Title [Quad]\lptitle.cue" / index: 1"
6)oddly the kbps shows but there is no numeric value prior to the kbps such as 1411kbps, not even a 0 just kbps. The codec column shows as ISO
Any suggestions would be appreciated or perhaps this is a bug with ISO files and the cuesheet utility?
Rev
