Topic: Find flac sample rate in VBA (Read 1005 times) previous topic - next topic
I want to query some flac files with VBA code to get their duration
From testing about 50 flac files the 3 bytes at offset 23 after "fLaC" seem to correctly return the Number of Samples.
Then this must be divided by the sample Rate for total number of Seconds
But I cannot locate the sample rate in the Stream info block, where I believe it is stored.
Can anyone help me find this?
Re: Find flac sample rate in VBA
Probably going to be easier and more reliable to use a library like libflac or ffmpeg to get the file metadata rather then try to parse the streams yourself.
I am using metaflac.exe but want to get the duration into my own app, rather than Shell to DOS window.
I've spent a few hours reading the info in that link but can't understand it.  What are numbers inside  <> chars?
I did  a bit-compare of a 44100 and 96000 and found byte offset 29 (after fLaC) had the last 4 bits as 1001 for 44100 and 1011 for 96000. But this wasn't consistent with "0111" often found.
Can someone better interpret that link and explain it to me ?  Or tell me how I might find the sample rate. I have seen code for this but it's in a format (language) I don't know.
^^^ Metaflac calls libflac, which you can also do directly from your program.
That sounds ideal. Would you have any examples of calling libflac from VBA ?
The sampling rate is at offset 12h. It is backwards in big-endian format.
Thanks very much.  Off to see how I can implement that.
Sorry, I'm just not finding it.. perhaps compounded by the big endian translation (which I'm just figuring out).
If the image works, which bytes are offset 12h ?  It should convert to 44100.
These.
Brilliant. All sorted. Thanks very much j7n
I note this in the flac site
<3>    (number of channels)-1. FLAC supports from 1 to 8 channels
Does this mean byte 3 should be 1 if the file is mono (single channel) ?
Not a whole byte but 3 bits just after the sampling rate at 14h. The remaining 1 bit is the most significant of the bit depth.
Thanks muchly it's a big help understanding the info at https://xiph.org/flac/format.html.
One other question - where it shows
METADATA_BLOCK_STREAMINFO
<16>    The minimum block size (in samples) used in the stream.
Does this mean the 16 bits immediately following "fLaC"  ?
After fLaC and 4 additional bytes of block_type and its length.
