Semicolons Are Replaced by Commas when Editing Tags 2021-01-14 17:25:57 When I open up tags for automatic editing, I've noticed that multi-value, semicolon-separated tags have their semicolons replaced by commas. Is there any way around this behaviour? Obviously I can use the $replace function, but that has the unwanted side-effect of replacing commas that are supposed to be there. Thanks.
Re: Semicolons Are Replaced by Commas when Editing Tags Reply #1 – 2021-01-14 18:19:51 Semicolon, for multi-value metadata types and input in Foobar, is more akin to a "placeholder" for a separator...Meaning an MP3 with id3 container in place of the semicolon you type, it will actually have a NUL injected, which in turn gets displayed as a comma in the main program GUI.For Flacs/vorbis, which is a container allowing multi-value declarations, the same will trigger 2 (eg) Artists fields to be written, which then again Foobar displays as separated by comma.Hope this helps, as this can be very confusing. Might help to look/check these in another tag editor or mediaplayer.c. Last Edit: 2021-01-14 18:22:23 by alec.tron
Re: Semicolons Are Replaced by Commas when Editing Tags Reply #2 – 2021-01-15 08:10:21 $meta_sep I think?https://wiki.hydrogenaud.io/index.php?title=Foobar2000:Titleformat_Reference#.24meta_sep.28name.2Csep.29
