Without roaming files, am I SOL? 2021-01-11 01:05:53 Hello, I am attempting to transfer over my old trusty f2k setup/themes to my new computer. However, I believe made a mistake when transferring foobar to my new computer, in that I only copied the program files over....A few hours of digging online and troubleshooting, made me realize that I should have copied the roaming files over as well. Since I don't have access to my old computer anymore, can I salvage at least some of my old F2k configuration using only the "foobar2000" program files, or will i have to start over?Thanks in advance for everyone's time!
Re: Without roaming files, am I SOL? Reply #1 – 2021-01-11 15:19:04 In short, yes, you are SOL'd With a standard install, all customizations are kept in the user folder. (So different users can have different themes)With a portable install, everything is in a single install folder. (So it can be copied easily and run without installing it)There are some pretty nice pre-made themes available though -Eole (CUI)Georgia (new SMP)StrigUI (DUI)CaTRoX QWRTripleQ(I have not tried them all, just linking)
Re: Without roaming files, am I SOL? Reply #2 – 2021-01-11 15:26:53 This would be a good time to remind people reading this to backup their foobar install. There's a component for this https://www.foobar2000.org/components/view/foo_jesussome more themes ~ https://audio-file.org/2020/05/01/foobar2000-cui-skins-themes-wallpapers/ Last Edit: 2021-01-11 15:41:45 by 2tec
Re: Without roaming files, am I SOL? Reply #3 – 2021-01-13 14:11:34 Quote from: anamorphic on 2021-01-11 15:19:04With a standard install, all customizations are kept in the user folder. (So different users can have different themes)With a portable install, everything is in a single install folder. (So it can be copied easily and run without installing it)Everything can be in single folder even with not portable install. Just remove file user_profiles_enabled after installation.
Re: Without roaming files, am I SOL? Reply #4 – 2021-01-19 13:08:39 Thanks guys! I appreciate all the help
