Topic: Should I leave the drive cache checked at all times  (Read 617 times) previous topic - next topic
I'm using a EAC 1.6 with Pioneer BDR-XD07UHD USB DVD/Blu-Ray Burner
Re: Should I leave the drive cache checked at all times
https://wiki.hydrogenaud.io/index.php?title=EAC_Drive_Options#Drive_caches_audio_data
        If the "Detect Read Features..." function reports "Caching : Yes", it is important that you enable the cache flushing routine by checking the "Drive caches audio data" box.
        If the "Detect Read Features..." function reports "Caching : No", it is not necessary to enable the flushing routine. Checking the "Drive caches audio data" box with drives that are reported by EAC as not caching will not improve EAC's accuracy. It won't improve EAC's ability to detect errors nor EAC's ability to correct them. What it will do however, is reduce your ripping speed and shorten the life of your drive.
korth
I'm having a real hard time with ripping cd's with this drive. Sometimes it works and other times it doesn't. It doesn't seem to matter what options I select in drive options unless when I select detect read features and drive cache get's checked then it always works. Seems to be a random problem with ripping audio cd's.
You should leave the "Drive caches audio data" box checked all the time based on that statement.
The extraction logs in the other topic show the box wasn't checked.
Defeat audio cache      : No
Should say YES when box is checked.
korth
If ripping the same CD twice on the drive produces two different results, you probably have a faulty drive that needs to be replaced.
