Should I leave the drive cache checked at all times 2021-01-08 23:06:54 I'm using a EAC 1.6 with Pioneer BDR-XD07UHD USB DVD/Blu-Ray Burner
Re: Should I leave the drive cache checked at all times Reply #1 – 2021-01-08 23:12:14 https://wiki.hydrogenaud.io/index.php?title=EAC_Drive_Options#Drive_caches_audio_dataQuote If the "Detect Read Features..." function reports "Caching : Yes", it is important that you enable the cache flushing routine by checking the "Drive caches audio data" box. If the "Detect Read Features..." function reports "Caching : No", it is not necessary to enable the flushing routine. Checking the "Drive caches audio data" box with drives that are reported by EAC as not caching will not improve EAC's accuracy. It won't improve EAC's ability to detect errors nor EAC's ability to correct them. What it will do however, is reduce your ripping speed and shorten the life of your drive.
Re: Should I leave the drive cache checked at all times Reply #2 – 2021-01-08 23:23:22 I'm having a real hard time with ripping cd's with this drive. Sometimes it works and other times it doesn't. It doesn't seem to matter what options I select in drive options unless when I select detect read features and drive cache get's checked then it always works. Seems to be a random problem with ripping audio cd's.
Re: Should I leave the drive cache checked at all times Reply #3 – 2021-01-09 04:01:48 Quotewhen I select detect read features and drive cache get's checkedYou should leave the "Drive caches audio data" box checked all the time based on that statement.The extraction logs in the other topic show the box wasn't checked.Defeat audio cache : NoShould say YES when box is checked.
Re: Should I leave the drive cache checked at all times Reply #4 – 2021-01-12 06:49:07 Quote from: RancelDoom on 2021-01-08 23:23:22I'm having a real hard time with ripping cd's with this drive. Sometimes it works and other times it doesn't. It doesn't seem to matter what options I select in drive options unless when I select detect read features and drive cache get's checked then it always works. Seems to be a random problem with ripping audio cd's.If ripping the same CD twice on the drive produces two different results, you probably have a faulty drive that needs to be replaced.
